Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Not that I know of. In P6, I usually use the two dropdown menus, on upper right of the document (render) window. It was in Poser 5 and it's in Poser 7 so I'm sure Poser 6 has it. Another option might be to select the figure in the hierarchy list?
If you keep your hierarchy editor open, you can select body parts there by clicing on their name.
This is if you don't like the drop down menu.
Also, if you select a body part, and you think you accidentally nudged it, hit a quick CTRL+Z (undo). It'll undo any movement, but the body part you just selected will stay selected. (At least, in P7 it will) HTH :)
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
I thinkt the easiest solution would be the hierarchy editor, as conniecat mentioned.
Keep it open and select your body part there, whithout moving anything. At least that's how I do it.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Is there any way in P6 -- feature, script, hack, whatever -- to select a figure or prop with the mouse by clicking on it directly without moving the figure? You know, when you click on a figure accidentally you can twist it horribly and throw it off the screen in a millesecond...
I don't mean "lock figure." I mean allowing the mouse to select but not move anything. Possible?
Gallery
