Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 5:11 pm)
If you render the first sequence as image files, you can then reverse the order of the files to give a smooth loop. You need to not use the first and last images on the reverse order so you get that smooth transition, otherwise you get a pause because the start and end are doubled.
I do it all the time for ani .gifs
You could also copy and paste the frames in reverse order in the animation graph.
Is there a way, in Poser 7, to select and animation and then paste it back in reversed? The reason is I have some BVH files that move the figure from one spot to another, and when the resulting video is looped the character jumps back to the starting location. I'd like to paste the animation back in to have them move back to the original position.
