Wed, Dec 4, 7:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Subject: gloss on obj import affects texture OH NO!
TheOwl ( ) posted Wed, 11 June 2008 at 10:31 PM · edited Sun, 01 September 2024 at 1:10 AM
I am experimenting with texturing. I made this hair model and tried the texture... when I noticed that the hair is so shiny like the original obj when I first imported the model. What can I do to remove the glossiness? What should I change in the material room?
Help!      :'{
Passion is anger and love combined. So if it looks angry, give it some love!
lesbentley ( ) posted Thu, 12 June 2008 at 12:02 AM
Try setting the "Specular_Value" to to a lower number or zero.
Jestertjuuh ( ) posted Thu, 12 June 2008 at 1:02 AM
Or using Black or Grey for "Specular_Color" works usualy as well.
I am not a complete idiot, some parts are missing :)
To go to my home page, click the banner below.
Check my freebies on a regular base, click the banner below.
TheOwl ( ) posted Thu, 12 June 2008 at 1:30 AM
got the spec value to 0 and it worked!
thanks! I am now on my way to mastering texturing.
texturing is Soooo hard in uv mapper classic!
Jestertjuuh ( ) posted Thu, 12 June 2008 at 1:47 AM
You mean making a UV map or aplying textures?
For texturing I just use a graphic program like PhotoShop or the Gimp etc.
TheOwl ( ) posted Thu, 12 June 2008 at 2:00 AM
I created a UV map of the same hair above and the sides look like v4 just did a brain surgery. It appears I have to deform something on the model to make it look right.
I am thinking of getting a more advanced texture software maybe deep paint 3d but I am a try-before-buy-guy and I find it difficult to find video tuts about it.
Life is cruel. X_X
Jestertjuuh ( ) posted Thu, 12 June 2008 at 2:16 AM
You can try to make the seems in a diferent place where they are not that visible.
ghonma ( ) posted Thu, 12 June 2008 at 3:03 AM · edited Thu, 12 June 2008 at 3:05 AM
Don't get deep paint 3D. That software hasn't been updated in years and is no longer supported by the company. It may not even run on modern CPU/GPUs. The only 3d painter worth getting is either Bodypaint or ZBrush. Bodypaint is more expensive but has a lot of features. ZBrush is not as great at texturing but can be used to sculpt and model as well. And you can get very good results in good old photoshop as long as your UVs are nicely laid out.
Also you can try using something like roadkill for the hair UVs:
Roadkill
And a tute for using it with Poser:
Roadkill with Poser
pakled ( ) posted Thu, 12 June 2008 at 7:00 AM
most modelers that have UVMapping capability (Wings 3d, Blender, and others), will let you set the Specular value on the model down, so that imports right the first time...if you want to try that route...;)
manoloz ( ) posted Thu, 12 June 2008 at 8:29 AM
You can also try 3d-coat for 3d painting.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
TheOwl ( ) posted Thu, 12 June 2008 at 11:31 AM
Hmmm.... the road kill tut looks promising. Is it easier to do it this way than to learn an entirely new software that will paint the texture directly on the model?
Does anyone have a texture guide specifically, a checkered box with different colors and with different numbers? I hope you could share if you have one.
manoloz ( ) posted Thu, 12 June 2008 at 11:36 AM
Here you go.
You want to have a uvunwrapper. The problem with the automatic unwrappers is, they're computer-editable-friendly. Not human friendly. Just check any uvmap done with zbrush, for example, they look like a bizarre crossword puzzle.
Visit my blog! :D
manoloz ( ) posted Thu, 12 June 2008 at 11:37 AM
Ooops, filesize limit...
Visit my blog! :D
manoloz ( ) posted Thu, 12 June 2008 at 11:41 AM
grrrrr, here is a link to one I made. Png version, son you won't get artifacts associated with jpg compression...
http://pixelwarrior.juanmanuel3d.com/images/uvmap%20pattern.png
Visit my blog! :D
TheOwl ( ) posted Thu, 12 June 2008 at 12:28 PM
Thanks for the pattern manoloz.
Now I just have to exert some more effort and I know my work shall bear fruits.
TheOwl ( ) posted Thu, 12 June 2008 at 9:08 PM
heee heee heeeh
I think I am beginning to get it now. That Road kill tut taught me well. With this kind of mapping I  was able to fix the sides.
