Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
I've always used "4" to force limits the same way. I don't have P7, but they did make a change in P6. The parameter is now "1." It will still respect "4," but will change it to "1" on saving back to the library. "1" works the same as "4" in earlier versions.
Perhaps they made a further change in P7. May need to use "1" now.
John
I agree the correct digit should be 1. I used 4 as that is what Easypose changes it to and decided to change them all in one go by using the Find/Replace in Wordpad. Didn't type the forceLimits parameter correctly and didn't notice until after I posted.
Must stop burning the candle at both ends. At least occasionaly.....
Using P7 with SR3. Has the option to force poser to use limits by setting the above parameter to 4 in the cr2 been changed with the latest service release?
Previously, when setting it to 4 it didn't matter whether the Force Limits option was checked or not, movement was always restricted. Now, you appear to have to have the Force Limits option checked to restrict the range of motion.
Is it Poser - or my installation?
Never Mind, my bad down to Typos.............
