Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
Quote - Uncheck under edit - General Preferences - Misc the "Check for updates at launch"
That was checked already but thanks!
Quote - Poser does a "duplicate license use" check on the local network, which you can't turn off.
Is this Poser Pro that does this? Because Poser 7 does not try to connect.
PaganArtist:
Uncheck. Uncheck.
Re-read the post from Jules53757
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
It also does a local network call when using the render queue or when rendering as a separate process
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Quote - PaganArtist:
Uncheck. Uncheck.
Klebnor
When I mean checked I mean I checked that it was unchecked already. Sorry.
Quote - It also does a local network call when using the render queue or when rendering as a separate process
Okay that makes sense since i have it set to render in a separate process. Thanks!
Each time I open Poser Pro it wants to connect to the internet even though there is no internet connections enabled on the machine I use Poser Pro on. The machine I use it on is strictly a render only machine so how do I get Poser Pro to stop trying? It messes things up and sometimes I get an error as I am working that poser pro has stopped working and shuts down.
Thanks!
Poser Pro
Vista 64
Intel quad-core
8 GB Ram
My Facebook Page
