Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
To rotate an image map, select VU mapping instead of UV on the image map node.
To rotate a procedural texture, see nruddock's post in this linked thread.
what I should be."
Murakami)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2750028&page=2#message_3311619
And to make a repeating pattern, just change the U_Scale and V_Scale on the image map node. It will tile the image.Use values that are the inverse of how many times you want it to tile. Use a math node to calculate the factor. See the linked post.
Yes. The weave pattern is an image (which I decode with nodes to calculate which threads go over/under other threads.) By scaling and tiling this image, I can scale the pattern up or down easily.
do you have any other trick for texturing? this divide function is really amazing.
You mean specifically doing 2D geometrical operations with image maps in nodes? Sure. Tons. What do you want to know about?
Tile with mirroring.
Rotate an image to any angle.
Non-linear scaling/stretching.
Make a kaleidoscope from any image.
Turn a linear gradient into a circular gradient.
Perform mapping conversions - for example equirectangular to angular map. (For panorama to IBL format.)
Blur.
Attached Link: Image filters: Gaussian, Mean, and Median
I didn't discuss blurring in VSS, I don't think. The blur thread is here.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Attached Link: Dumb Question-Is There Any Way to Flip a texture 90 degrees?
Some basic 90 degree rotation here.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Attached Link: Positioning an image overlay
Precise image positioning and overlaying.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Attached Link: Need P5 Mat Room Help Again: Spinning A Texture
How to rotate to any angle. (18 nodes, not 20 hehehe)(See it's not just me who comes up with this stuff.)
can i use this pic and make a pattern out of it, or any other pic i import in poser?
![](http://img233.imageshack.us/img233/4135/30086371aq2.jpg)
![](http://img233.imageshack.us/img233/1329/57393963rz2.jpg)
and my second question is can we rotate the texture?
