Thu, Nov 7, 5:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 05 9:36 pm)
Subject: Stripes Shader?
SSAfam1 ( ) posted Wed, 12 November 2008 at 8:16 PM · edited Thu, 07 November 2024 at 5:25 AM
Can anyone point me in the direction of a shader that'll give me stripes to change the texture on a tie?
Thanks.
hborre ( ) posted Wed, 12 November 2008 at 10:32 PM
Check castleposer for shader tutorials.  I believe there is a tute that may answer your question.
Link below:
http://www.castleposer.co.uk/
bagginsbill ( ) posted Wed, 12 November 2008 at 11:02 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=250140
And if you want to go "deep" - read this exchange we had when that tutorial was written.
bagginsbill ( ) posted Wed, 12 November 2008 at 11:03 PM
By the way, John's Castle Poser tutorial shader will produce stripes, but they will not be anti-aliased. You'll get jaggies in some cases.
If you encounter that problem and would like to see how to fix it, let me know. It's just one more node.
SSAfam1 ( ) posted Thu, 13 November 2008 at 7:01 AM
Thank you both.
BB---very informative thread. It answered another question of mine---where to go to alter the direction of the stripes. :thumbupboth:
Dead_Reckoning ( ) posted Thu, 13 November 2008 at 7:22 AM
Hello BagginsBill
Yes Please, I would love to know how to fix the stripes.
I was just playing with this last week and figured out Vertical stripes.
Still haven't figured out how to get them small enough to look like a Ref's Shirt though.
And, certainly do have the jaggies.
DR
Quote - By the way, John's Castle Poser tutorial shader will produce stripes, but they will not be anti-aliased. You'll get jaggies in some cases.
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
bagginsbill ( ) posted Thu, 13 November 2008 at 11:19 AM · edited Thu, 13 November 2008 at 11:21 AM
You guys inspired me to do another free shader pack. I decided to make very feature-rich stripe shaders that are very easy for you to configure. The math is pretty tricky on some of these.
You'll be able to make any of thousands of variations in minutes.
Here's a teaser. (Click for full size) I've included a few Holiday themed ones since Christmas is coming.
I'll let you know when it's ready.
EnglishBob ( ) posted Thu, 13 November 2008 at 11:35 AM
I like those. :-)
Is it easy to make soft-edged bands of colour that blend into each other with the same set-up, or is that a whole other thing? The reason I ask, is because I made a gas giant model the other day, ultimately for use in Vue - but I was wondering about using it in Poser too. I know my way around Poser materials a lot better than I do Vue's.
bagginsbill ( ) posted Thu, 13 November 2008 at 12:28 PM
Yes it is, although I wouldn't use the exact same setup. These stripes are meant to be incredibly regular repeating patterns, whereas the rings of a planet should be different sizes and should not repeat the colors. The use of the Mod operator to produce a repeating ramp is inappropriate for in this case.
But I'd still use Blender nodes as I'm doing here to blend the colors smoothly.
MaskimXul ( ) posted Thu, 13 November 2008 at 2:10 PM
Ohhh yeah, those are awesome! I love stripes!!
Quote - You guys inspired me to do another free shader pack. I decided to make very feature-rich stripe shaders that are very easy for you to configure. The math is pretty tricky on some of these.
SSAfam1 ( ) posted Thu, 13 November 2008 at 3:27 PM
OMG. This looks AMAZING!!!!
Is this a regular MT5 file or for Matmatic?
bagginsbill ( ) posted Thu, 13 November 2008 at 4:28 PM
Just mt5 files. I built them by hand - wasn't complicated enough to justify matmatic.
This way you can read what it does since I carefully laid everything out to make sense instead of spaghetti.
Well.... it makes sense to me anyway.
bagginsbill ( ) posted Thu, 13 November 2008 at 4:46 PM
I made 6 more for the set.
Any specific requests?
dadt ( ) posted Thu, 13 November 2008 at 4:51 PM
Great stripes,the only problem is that the stripes on the tie knots should be rotated 90 degrees compared to the main area of the tie.
bagginsbill ( ) posted Thu, 13 November 2008 at 4:52 PM
I noticed that - it's a very old tie for P4 woman from free stuff somewhere. I didn't have a good tie laying around.
Whatever tie you use, the UV map should be opposite for the knot. If it isn't I suppose you could use the grouping tool to re-assign those polygons to another material and then flip the diagonal on that second copy of  the shader.
SSAfam1 ( ) posted Thu, 13 November 2008 at 4:58 PM
Quote - I made 6 more for the set.
I seriously LOVE you. Just what I needed!
Can we use this (with adjusted settings of course) to turn a regular black suit into pinstripes?
bagginsbill ( ) posted Thu, 13 November 2008 at 4:59 PM
Yep - grouping tool is your friend. If you have a tie like this, just select those polys and make a new material for the knot. Then when you load the shader, you'll use the "Flip" setting in it. (You just change a 0 to a 1 or vice versa - you'll see what I mean later when I post the shaders.)
bagginsbill ( ) posted Thu, 13 November 2008 at 5:06 PM · edited Thu, 13 November 2008 at 5:07 PM
> Quote - > Quote - I made 6 more for the set. > > > > Any specific requests? > > > I seriously LOVE you. Just what I needed! > > Can we use this (with adjusted settings of course) to turn a regular black suit into pinstripes?
Yes, as long as the suit has good straight UV lines.
Some don't.
You'll also need to change the specular a bit and possibly add some Noise for bump. Here's an example.
But if you really want a pin-stripe suit fabric, you should use my loom and build a realistic cloth with threads and fibers.
bagginsbill ( ) posted Thu, 13 November 2008 at 5:15 PM
Here's what I mean about using the loom.
This tie shader has no "texture" - they're just smooth stripes.
If you want suit cloth, you need a texture like this.
See all the detail? Threads and fibers, and the pin-stripe is not continous because it is a thread and goes under the other threads sometimes.
I made this pin-stripe suit material as a tileable image using my Loom. You can use the Loom shader directly on a suit, or you can use it to design and render a repeating tile.
Here is that tile on a larger cloth.
nruddock ( ) posted Thu, 13 November 2008 at 5:16 PM
> Quote - Any specific requests?
How about these ?
I have a few other challenging ones from a Google image search if your bored 😉
bagginsbill ( ) posted Thu, 13 November 2008 at 5:26 PM
Quote - > Quote - Any specific requests?
How about these ?
Heheh. I knew somebody would show me some textured fabrics. Those would be a job for the Loom, combined with this stripe generator.
One step at a time...
bagginsbill ( ) posted Thu, 13 November 2008 at 5:51 PM
Hmmm. I'm running out of time. I have to get to bed as I'm heading to the airport at 3:30 am tomorrow.
So here ya go - see if you can make them work for you.
http://sites.google.com/site/bagginsbill/free-stuff/stripes
On that page is Stripes.zip - with a runtime in it. There's just some shaders in the materials folder - no scripts.
EnglishBob ( ) posted Fri, 14 November 2008 at 3:17 PM
Hehe. That works nicely, thanks BB. :-)
