Mon, Feb 17, 6:33 PM CST
Renderosity Forums / 3D Modeling
Welcome to the 3D Modeling Forum
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 16 8:08 pm)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the
MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Subject: metasequoia
airflamesred ( ) posted Tue, 02 December 2008 at 6:19 AM · edited Sun, 28 July 2024 at 8:59 AM
Whipping up meshes in meta then exporting as .cob for use in bryce. Now , if I put a pic tex on it bryce goes to a default of parametric mapping. This doesn't work and I end up using object side or object front.
I assume this is something to do with the mesh rather than bryce.
Anyone got any thoughts on the matter?
thanks
Mark
EnglishBob ( ) posted Tue, 02 December 2008 at 6:45 AM
I assume that the meshes you're making have no UV mapping, which is why Bryce uses the default. If Metasequoia can't generate mapping, can you export as OBJ and map in an external application - UVMapper would be the obvious choice?
airflamesred ( ) posted Tue, 02 December 2008 at 8:32 AM
Thanks Bob.
I think thats what I'm asking - does meta generate UVs.
EnglishBob ( ) posted Tue, 02 December 2008 at 8:56 AM
Attached Link: Compose - download link
I'm not an expert on Metasequoia or Bryce - but as far as I know the COB format can incorporate UV mapping. The question is whether it's Meta's export, or Bryce's COB import which is to blame.
Compose is a small Java app which, among other useful things, converts between COB and OBJ. If you were to convert one of your COBs to OBJ, then look at it in UVMapper, that would soon tell you whether Metasequoia had included UVs.
airflamesred ( ) posted Tue, 02 December 2008 at 9:16 AM
Just put it through crossroads to convert it and into UV mapper and lo and behold.......Just got to  figure out mapper now! I wonder if theres an app to convert 1p into a £!
thanks
