Vue F.A.Q (Last Updated: 2024 Sep 04 4:56 pm)
I first drag and translate the camera roughly with the usual widgets (in the viewports), just like any other object.
Then I use that camera control (with the horizontal and vertical loops) for smooth fine camera tuning. I also fine-tune with the focal length and use that with large increases (and together with the selection marquee) to examine critical parts of the image with fast sample renders.
It also helps to drag the left edge of the right panel as far to the left as you can, to enlarge the preview window. If you go too far, the preview window pops up to the next level and gets small again. If this happens, just re-size back toward the right a little bit.
Camera adjustment does take significant tweaking. Not sure how it could be improved though.
My tutorial on Vue camera focal length effects may interest you:
www.art-head-start.com/Free/Tutorials/tutorial-focal-length.html
I'm not sure if you might be suffering from what I'm about to write but it's a possibility.
There's some kind of bug in Vue that, sometimes, when you have a selected render area active (button "use render area" on) and you try to drag objects in the other viewports using the gizmos, the drag isn't smooth. This doesn't happen always and I couldn't determine a pattern for it to appear. I've seen it happening in Vue6, in Vue7, under XP32 and under Vista64, with different graphic cards, etc. If I just uncheck the "use render area" button, it becomes smooth again.
Hi all. Beginners question for you.
I'm finding it VERY frustrating to place the camera exactly where I want on my geometry, when I click and drag the main camera it's not a smooth motion, it's very jerky.
any reason why?
How do you guys position the camera with accuracy?
Dell XPS M1730
Intel Core 2 Duo T9500 2.6Ghz
500GB (2x 250GB) RAID 1 Sata HDD
4GB RAM
Nvidia GeForce 9800M GTX SLI
