Sun, Feb 16, 6:32 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Relinking DYN files to PZ3 file
SimonWM ( ) posted Mon, 15 December 2008 at 8:03 PM · edited Tue, 30 July 2024 at 2:30 AM
After letting my dynamic hair simulation run thru the week-end I accidentally deleted the hair object from the scene after having saved the file.  Since I had already saved the file i thought all was good. Well, I closed Poser and opened it again but no luck the file won't show dynamics in the hair.  I can see my DYN file is still on my hard drive but the hair stays static.  I was able to see the simulation before I erased the hair but now somehow the PZ3 file is not reading the information in the DYN file, even though I never saved after deleting the hair object.  Is there a way to check the syntax in the PZ3 file? The dynamic hair files are 34 & 38MB right hair and left hair.
nruddock ( ) posted Tue, 16 December 2008 at 1:25 PM
Quote - Is there a way to check the syntax in the PZ3 file?
Setup a simple scene with a small hair simulation, run the sim and save the scene.
You should then be able to see where and how the DYN file is referred to.
Provided you have a text editor capable of opening the PZ3 you want to fix, you shouldn't have any trouble editing in the necessary info.
