Wed, Jan 8, 12:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 07 11:07 am)
Subject: Any Stitch Witch users?
MeInOhio ( ) posted Sun, 21 December 2008 at 8:39 AM · edited Tue, 07 January 2025 at 9:55 PM
If so, what are you doing if you want a solid color for a collar for example? I thought I could just leave it blank and it would use the background color. But it adds a transmap and I think it masks it out in Poser if you do apply some sort of texture. I thought about saving some plain colored textures, but I'm not sure how big to make them etc.
thanks.
kalon ( ) posted Sun, 21 December 2008 at 9:22 AM
I use StitchWitch and use your second option.
If you haven't really created any transparent areas on your outfit, I imagine you could leave off the transmap and set the color in the poser material room. Or you could remove the transparency for the collar if it's a separate material in the material room.
If you use a solid colored texture map, be sure to save at 300 dpi. You can make them fairly small as StitchWitch tiles them, and since they're solid they'll be seamless.
I don't know what graphic application you're using, but you might look into brushes or filters to give even your solids some sort of weave or fabric like texture.
kalonart.com
3anson ( ) posted Sun, 21 December 2008 at 9:30 AM · edited Sun, 21 December 2008 at 9:31 AM
save your solid colour textures at 2048 x 2048 as a general guide, or at 1024 x 1024 if it is only to be used on small items.  if you want the collar to be different to the main item (unless the collar is a separate piece) you will need to use a separate new layer otherwise S/W will treat it as a transparent bit.
do the main layer up to where the collar is to start, and then on a NEW layer(spline) start the collar at the same points as the main layer ended. seemed to work for me without messing with transmaps (which i still don't know how to use properly)
MeInOhio ( ) posted Sun, 21 December 2008 at 10:21 AM
Thanks for the tips.
