Mon, Feb 17, 7:22 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
Subject: Lighting tricks
ice-boy ( ) posted Wed, 11 February 2009 at 5:38 AM · edited Sun, 19 January 2025 at 6:45 PM
what are your tricks when it comes to lights?
-sometimes when i use a bright IBL i also add a light with only specular. that way i have 3 lgihts. one direct light +IBL + specular only to fill in some parts that were missing specular.
-i use Olivers IBL image gels.
-i also a lot of times use AO for fake ambient light.
-blury ractraced shadows looks very much like noise. even with good settings. i found out by using Bagginsbills lights that if you use a bright IBL you dont see the noise. because they are so bright.
-for DM shadows i always change the shadow cam.
what are your tricks?
Anthanasius ( ) posted Wed, 11 February 2009 at 5:44 AM
Hi
I think all depend of your scene ...
Génération mobiles Le Forum / Le Site
richardson ( ) posted Wed, 11 February 2009 at 9:53 AM
I have a box primitive that I parent or point my lights to. When I get a lightset that works,  I add or point a second box towards the camera (red box). This sets a stage to replicate the success as long as the point of interest is at the box's position...
I then delete all subject matter and save as a PZ3.. "!_White_lightset.pz3" and put it where I can find it.
Having lights parented to a box is great for quick adjustments... just grab the box and lift or "Yrot"...etc. Cool in animation...disco baby.. (not really..)
SSAfam1 ( ) posted Wed, 11 February 2009 at 11:46 AM
Bookmark.
momodot ( ) posted Wed, 11 February 2009 at 12:25 PM
richardson, I think you can change the suffix of that .pz3 to .cr2 and place it in your Figure Library for quick access.
richardson ( ) posted Wed, 11 February 2009 at 1:09 PM
Props???
ice-boy ( ) posted Wed, 11 February 2009 at 1:43 PM
Quote - I have a box primitive that I parent or point my lights to. When I get a lightset that works,  I add or point a second box towards the camera (red box). This sets a stage to replicate the success as long as the point of interest is at the box's position...
so when you move the box the light folows it?
richardson ( ) posted Wed, 11 February 2009 at 1:59 PM
Yep. It can get tricky with some lights.. Try it out.
ice-boy ( ) posted Fri, 24 April 2009 at 9:55 AM
i am still trying to make a light that has very wide specular.
sometimes you want to use lights that are like spot lights that have a very small specular. but for some area lighting you want soft and wide specular. like a window for example. if i make 3 or 4 spot lights that are very close together i can make a pretty good lighting that is like a window. but the specular looks wrong. very bad.
any new tips on that?
pjz99 ( ) posted Fri, 24 April 2009 at 10:27 AM
Online Now!
Specular size and behavior is a lot more easily controlled by the material the light falls on, not so much by the light itself.
My Freebies
ice-boy ( ) posted Fri, 24 April 2009 at 10:32 AM
but different lights have different chareteristics. if i chagne it in the material then it will be the same on all lights.
ice-boy ( ) posted Tue, 28 April 2009 at 11:40 AM
sometimes you want to control the specular and diffuse in the lights.  you dont have numbers bot only color. this is how i connect two math nodes. so i can type in numbers. ignore the value 2. only value 1.
Acadia ( ) posted Tue, 28 April 2009 at 12:50 PM
All kinds of lighting tips and tricks in the following thread
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2734086
ice-boy ( ) posted Tue, 28 April 2009 at 3:29 PM
i thought we would share more tricks acadia. thats why i opened this thread. to talk about lighting .
santicor ( ) posted Wed, 29 April 2009 at 5:59 AM
which kind of light is it,  or  what kind of light settings is it,  where you can actually "cast darkness" with the light.
I have tried  turning simple  spot lights  to  black color,  but that is not achieving  a darkening of the area  that the light hits.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
ice-boy ( ) posted Wed, 29 April 2009 at 6:31 AM
you need type a negative number.
ice-boy ( ) posted Fri, 15 May 2009 at 3:57 PM
shadows only -lights
sometimes they use a trick to cast only a shadow. no lighting. so they position a light and make it cast only a shadow. they dont use 100% black shadows. sometiems you want to add a shadow somewhere but without the lighting  for a dramatic effect.
poser i think doesnt have an option to make only shadows.  but we can use negative lights.
so what we do is:
-we position a light that we like.
.we duplicate the light
-the first light is a positive number. the second light is the same number but negative. the second light doesnt have shadows.  the second light will take away the lighting but leave the shadow.
ice-boy ( ) posted Fri, 15 May 2009 at 3:58 PM
here i used one IBL and two lights.
bagginsbill ( ) posted Fri, 15 May 2009 at 6:24 PM
Quote - but different lights have different chareteristics. if i chagne it in the material then it will be the same on all lights.
Exactly! This is why I want a Specular node with a pulldown for Choose Light: All, Main, Rim, Window etc.
ice-boy ( ) posted Sat, 16 May 2009 at 4:41 AM
interesting BB. do other software have this?
so you would have more specular nodes? for example 5 specular nodes for 5 lights?
ice-boy ( ) posted Sat, 16 May 2009 at 5:34 AM
i guess it is impossible to make the light appear bigger since in poser all lights are a point.
maybe we need specular from HDR? or specular on IBL?
ice-boy ( ) posted Sun, 17 May 2009 at 12:52 PM
CORNERS
sometimes you can notice in rooms that the corners from the walls are darker. thats because of how the light bounces around. with AO we can make it look better.
but with negative lights we have full control.
first make a spot light and turn of shadows. we dont need shadows because we will position the spot light direct in the corner . make the intensity negative. negative lighting. we want to make it darker and not brighter.
ice-boy ( ) posted Sun, 17 May 2009 at 12:53 PM
ice-boy ( ) posted Sun, 17 May 2009 at 12:54 PM
with the negative spotlight
without
Latexluv ( ) posted Sun, 17 May 2009 at 6:38 PM
This trick has been around for a while but I'm not sure many people know about it or use it. I first saw it in some light sets that I bought at RuntimeDNA. Traveler created several nice light sets, Lighworks Noir and Lightworks Studio Series. These light sets use a light that is dialed into the negative and which he labeled a "Dampener" light. Here's the Studio Series 1, Light Set 2. Pretty nice. I play around occassionally with negative lights.
Weapons of choice:
ice-boy ( ) posted Mon, 18 May 2009 at 3:34 AM
you can use negative lights even on figures. sometimes you have some part on the body to bright.
but its not good to use big numbers. -30 is pretty dark. i would use -5 or -10
