Sun, Feb 16, 11:58 PM CST
Vue F.A.Q (Last Updated: 2025 Jan 30 6:52 am)
Subject: Populate
IronHorse61 ( ) posted Fri, 20 March 2009 at 3:18 PM · edited Fri, 17 January 2025 at 10:54 AM
I have a terrain where I put bushes, they cover the hole terrain without any problem. But when I add trees to the eco system the bushes dissapear ?  Decay near foreign objects is not marked!
chudo121 ( ) posted Fri, 20 March 2009 at 3:23 PM
Maybe it is something to do with the relative presence/scale relationship ?
The most beautiful experience we can have is the mysterious. It is the fundamental emotion that stands at the cradle of true art and true science...
Rutra ( ) posted Fri, 20 March 2009 at 3:24 PM
Are the trees and bushes in the same ecosystem?
bruno021 ( ) posted Fri, 20 March 2009 at 6:12 PM
You should use different layers of ecosystems.
Ecosystems populate a surface, if you say that trees have a presence of 1.000, and bushes also have a presence of 1.000, you can't have as may trees as bushes, because the trees use a lot more surface than bushes, so the bushes may disappear to make room for the trees.
If you use different layers for your trees and your bushes/grasses, then the problem will go away.
IronHorse61 ( ) posted Mon, 23 March 2009 at 9:28 AM
Thank´s for the information, I will try when I get home from work :-)
