Sun, Feb 2, 4:50 PM CST
Vue F.A.Q (Last Updated: 2025 Jan 30 6:52 am)
Subject: resources and memory purge in 7.4
FCLittle ( ) posted Fri, 15 May 2009 at 4:39 PM · edited Sun, 02 February 2025 at 1:51 PM
So it seems that 7.4 is even touchier when it comes to system resources, but what I dont understand is that when I purge the memory, nothing seems to happen.  Anyone else notice this?  And, if these problems persist, is there a way to uinstall 7.4, or revert back to the last version without having to actually uninstall the entire program?
Peggy_Walters ( ) posted Sat, 16 May 2009 at 3:11 PM
Purge memory only helps when Vue has something it can purge.  If you just deleted a big object, then purge will help.  If you just moved something around, then purge won't make a difference.
LVS - Where Learning is Fun!
FCLittle ( ) posted Sat, 16 May 2009 at 8:21 PM
See, it always seemed to have some effect though....I would do a lot of operations until the levels dropped too low, then purge, they would rise again, albeit for only a little longer, and I would continue this until it didn't seem to have any effect....I'm finding it seems to be better now.....
