Fri, Jan 10, 7:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Poser 8... First Impressions
pjz99 ( ) posted Thu, 20 August 2009 at 10:13 AM
This function (and the associated Get function) is not detailed in the Poser Python Methods manual included in Poser 8 but I can probably get it sussed by example from others like it.  I'll try contacting Colm at RDNA, thanks.
My Freebies
indigone ( ) posted Thu, 20 August 2009 at 10:14 AM
Quote - More good news. I fixed the arrow keys in the library GUI. They used to stop working randomly. No more!!!!
Damn, I've been working on that problem for 9 weeks.
Ooh that's cool.  I thought it was me :)
Indi.
pjz99 ( ) posted Thu, 20 August 2009 at 10:18 AM
lkendall ( ) posted Thu, 20 August 2009 at 10:18 AM
*"I see how to do this, but I don't know if it's allowable to redistribute this script.  I didn't blink about the materials Diffuse_Value loop script I modified the other day just because it's so simple (it's only 15 lines or so) but this is a little more substantial.  Who is "Shaderworks"?"
"This function (and the associated Get function) is not detailed in the Poser Python Methods manual included in Poser 8 but I can probably get it sussed by example from others like it.  I'll try contacting Colm at RDNA, thanks."*
If changes cannot be redistributed, one could always save the changes as a textfile, and give instructions on where to insert the changes. I don't mind doing for myself what I can, but I do not know how to program in Python.
LMK
ice-boy ( ) posted Thu, 20 August 2009 at 10:22 AM
is it now very complicated to use python for samples?
ice-boy ( ) posted Thu, 20 August 2009 at 10:24 AM
Quote - > Quote - Is there already a Python script that exposes the Shadow Samples.
Could it be added easily to an existing script (such as the Render Control Panel)?
LMK
There is a P8 included script for making a new lighting control panel. I think this could be added pretty easily to it.
It is in the menu Scripts/Partners/ShaderWorks/Light Panel
It could also be added to the Scripts/Partners/Dimenion3D/Render Firefly
that would be fantastic.
bagginsbill ( ) posted Thu, 20 August 2009 at 10:33 AM
ShaderWorks is semidieu, not Colm.
pjz99 ( ) posted Thu, 20 August 2009 at 10:34 AM
The parameter code is not kParmCodeLITESHADOWSAMPLES and I'm not interested enough to try to guess.  I can make it one-way easily enough (you can set it without examining what it was before you ran the script).
My Freebies
bagginsbill ( ) posted Thu, 20 August 2009 at 10:36 AM
It's not a parameter. You don't use SetParameter, you use SetShadowSamples(x). To read the value, you use ShadowSamples().
ice-boy ( ) posted Thu, 20 August 2009 at 10:38 AM
we set this for every light or can we decide?
pjz99 ( ) posted Thu, 20 August 2009 at 10:39 AM
Quote - ShaderWorks is semidieu, not Colm.
This person?
http://www.runtimedna.com/forum/member.php?u=53652
Thanks.
My Freebies
pjz99 ( ) posted Thu, 20 August 2009 at 10:40 AM · edited Thu, 20 August 2009 at 10:40 AM
Quote - It's not a parameter. You don't use SetParameter, you use SetShadowSamples(x). To read the value, you use ShadowSamples().
err, oops, thanks.
My Freebies
ice-boy ( ) posted Thu, 20 August 2009 at 10:43 AM
come on .
post this already he he he he :)
pjz99 ( ) posted Thu, 20 August 2009 at 10:52 AM
Bagginsbill, are these functions in the current distribution of Poser 10199, or are they only in your early copy of SR1?  I'm expecting I can get the value of a light's shadow samples by something like so:
shadsamples= l.ShadowSamples()
(where l is a loop value that refers to the current actor in the loop)
However the interpreter chokes on this:
AttributeError: ShadowSamples
It seems either I have the syntax wrong or this attribute isn't exposed to the python interpreter.
My Freebies
msg24_7 ( ) posted Thu, 20 August 2009 at 10:54 AM
Quote - This is the person Shaderworks?
http://www.runtimedna.com/forum/member.php?u=11265
semidieu is ShaderWorks...
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
pjz99 ( ) posted Thu, 20 August 2009 at 10:58 AM
Thanks, I will mail him.
My Freebies
bagginsbill ( ) posted Thu, 20 August 2009 at 11:04 AM
You know, it may be an addition after release. I'm running a preview of SR1, and Stefan only told me about this after release. I suspect that's why there's nothing about it in the product.
To be sure, run the script from Menu/Python Shell.
Pick the name of a light you have, and type:
dir(poser.Scene().Actor("nameOfYourLightHere"))
The dir listing will display all the methods on this light. If you don't see SetShadowSamples in there, then you don't have it.
bagginsbill ( ) posted Thu, 20 August 2009 at 11:04 AM · edited Thu, 20 August 2009 at 11:05 AM
This is my dir listing
['AddKeyFrame', 'AlignmentRotationXYZ', 'AltGeomFileName', 'AmbientOcclusion', 'AmbientOcclusionBias', 'AmbientOcclusionDistance', 'AmbientOcclusionStrength', 'AtmosphereStrength', 'BackfaceCull', 'Base', 'Bends', 'CastsShadows', 'Children', 'ClearLocalTransformCallback', 'ClearVertexCallback', 'CreaseAngle', 'CreateHairGroup', 'CreateValueParameter', 'Delete', 'DeleteKeyFrame', 'DisplacementBounds', 'DisplayStyle', 'DropToFloor', 'EndPoint', 'GeomFileName', 'Geometry', 'HairGroup', 'InternalName', 'IsBase', 'IsBodyPart', 'IsCamera', 'IsDeformer', 'IsHairProp', 'IsLight', 'IsProp', 'IsZone', 'ItsFigure', 'JointVertexWeights', 'LightAttenType', 'LightOn', 'LightType', 'LoadMaterialCollection', 'LocalDisplacement', 'LocalMatrix', 'LocalQuaternion', 'MarkGeomChanged', 'Material', 'Materials', 'Memorize', 'Name', 'NextKeyFrame', 'NumHairGroups', 'OnOff', 'Orientation', 'Origin', 'Parameter', 'ParameterByCode', 'Parameters', 'Parent', 'PointAt', 'PrevKeyFrame', 'RayTraceShadows', 'RemoveValueParameter', 'Reset', 'Restore', 'SaveMaterialCollection', 'ScaleMatrix', 'SetAlignmentRotationXYZ', 'SetAmbientOcclusion', 'SetAmbientOcclusionBias', 'SetAmbientOcclusionDistance', 'SetAmbientOcclusionStrength', 'SetAtmosphereStrength', 'SetBackfaceCull', 'SetBends', 'SetCastsShadows', 'SetCreaseAngle', 'SetDisplacementBounds', 'SetDisplayStyle', 'SetEndPoint', 'SetGeometry', 'SetIncludeInBoundingBox', 'SetLightAttenType', 'SetLightOn', 'SetLightType', 'SetLocalTransformCallback', 'SetName', 'SetOnOff', 'SetOrientation', 'SetOrigin', 'SetParameter', 'SetParent', 'SetRangeConstant', 'SetRangeLinear', 'SetRangeSpline', 'SetRayTraceShadows', 'SetShadingRate', 'SetShadow', 'SetShadowBiasMax', 'SetShadowBiasMin', 'SetShadowBlurRadius', 'SetShadowSamples', 'SetSmoothPolys', 'SetSplineBreak', 'SetStatic', 'SetVertexCallback', 'SetVisible', 'SetVisibleInReflections', 'SetVisibleInRender', 'ShadingRate', 'Shadow', 'ShadowBiasMax', 'ShadowBiasMin', 'ShadowBlurRadius', 'ShadowSamples', 'SmoothPolys', 'SpawnTarget', 'SpawnTargetFromGeometry', 'Static', 'TwistVertexWeights', 'ValueParameter', 'ValueParameters', 'Visible', 'VisibleInReflections', 'VisibleInRender', 'WeldGoalActors', 'WeldGoals', 'WorldDisplacement', 'WorldMatrix', 'WorldQuaternion', 'Zones']
pjz99 ( ) posted Thu, 20 August 2009 at 11:06 AM
Yeah I only have:
... 'Shadow', 'ShadowBiasMax', 'ShadowBiasMin', 'ShadowBlurRadius', ...
so it doesn't seem to be exposed.  Well, I guess we will wait until the SR is available.
My Freebies
ice-boy ( ) posted Thu, 20 August 2009 at 11:06 AM
if you fix the artifacts and add samples to SP1 then you are all amazing . and then poser 8 becomes a lot more.
ice-boy ( ) posted Thu, 20 August 2009 at 11:09 AM
Quote - Yeah I only have:
until today  i didnt care so much about SP1. but now? huuuuuuuuuuuuuuuuh. i am shaking :)
pjz99 ( ) posted Thu, 20 August 2009 at 11:10 AM
This will be a nice feature to have, for sure.
My Freebies
ice-boy ( ) posted Thu, 20 August 2009 at 11:13 AM
imagine how much time it takes to set up 5 lights to get smooth shadows. and it needs to generate 5 shadows.
here? only samples.
bagginsbill ( ) posted Thu, 20 August 2009 at 12:30 PM
Here's a more typical example. It may be hard to make out the difference in the shadow on the curtain, but if you zoom the image larger, it is easy to see.
This is with samples=19. Render time = 90 seconds. (No IDL, just IBL+AO)
Now with samples=100. Render time 200 seconds.
pjz99 ( ) posted Thu, 20 August 2009 at 12:37 PM
You are still getting that 1px garbage at the border of the image (not related to the point you're making about shadow blur), that really needs to be fixed in the final version of the SR.
My Freebies
bagginsbill ( ) posted Thu, 20 August 2009 at 12:43 PM
Yeah 1 pix garbage. I'll pound Stefan until he submits. ;-)
Here is samples=100, with IDL as well. The skin shader is a GC 2.2 shader and I made no adjustments, so it doesn't look as good as it should.
IC=50
ILQ=25
Render time 504 seconds.
ice-boy ( ) posted Thu, 20 August 2009 at 12:50 PM · edited Thu, 20 August 2009 at 12:51 PM
its a big diffrence. thank god that we will have samples. thaaaaaaaaaaaank god
can you render the same image with 50 samples? i want to see something.
ice-boy ( ) posted Thu, 20 August 2009 at 12:52 PM
Quote - Yeah 1 pix garbage. I'll pound Stefan until he submits. ;-)
Here is samples=100, with IDL as well. **The skin shader is a GC 2.2 shader and I made no adjustments, so it doesn't look as good as it should.
try lowering the intensity to 0,7 or 0,6.
lkendall ( ) posted Thu, 20 August 2009 at 1:19 PM · edited Thu, 20 August 2009 at 1:20 PM
[Pout] :(
I guess we will have to await the SR1 release. Though I for one would not refuse a "hotfix".
LMK
bagginsbill ( ) posted Thu, 20 August 2009 at 1:38 PM
I never saved the first test scene so I made a new one. This one shows the detail better, anyway.
Sample Size=5
5 seconds
bagginsbill ( ) posted Thu, 20 August 2009 at 1:39 PM
Sample Size = 19 10 seconds
Sample Size = 35 14 seconds
Sample Size = 50 18 seconds
bagginsbill ( ) posted Thu, 20 August 2009 at 1:40 PM
Sample Size = 70 24 seconds
bagginsbill ( ) posted Thu, 20 August 2009 at 1:41 PM
Sample Size = 100 32 seconds
pjz99 ( ) posted Thu, 20 August 2009 at 1:51 PM
Like the sample radius for indirect lighting settings, I presume this is pixel radius again?
My Freebies
bagginsbill ( ) posted Thu, 20 August 2009 at 3:05 PM
Eh? it's number of samples, I think. Same idea as IDL Samples - it's how many extra rays to shoot.
Whichway ( ) posted Thu, 20 August 2009 at 3:10 PM · edited Thu, 20 August 2009 at 3:10 PM
Good question. BB's description made it sound more like a pure number a la Samples, not Sample Size. And, btw, I never understood how Irradiance Caching is supposed to work for AO anyway.
Whichway
[Dang, not quick enough.]
Whichway ( ) posted Thu, 20 August 2009 at 3:15 PM
That 1 pixel business on the edge is definitely a sometime thing. I just posted a Poser 8 IDL render in my Gallery here and no such effect. In fact, I haven't seen it for a few days. My worst case, which persists, is where the backdrop is a single, very large square, with no polygonal subdivision, i.e., just four vertices. Then I even get the second thread's first render block to come back totally transparent!
Whichway
bagginsbill ( ) posted Thu, 20 August 2009 at 3:23 PM
I've been getting the random black second bucket too! I see it when pointing at the ground.
MikeJ ( ) posted Thu, 20 August 2009 at 3:25 PM · edited Thu, 20 August 2009 at 3:26 PM
If you can somehow get it where the shadow is sharp near where the ball touches the floor, then blurs more with distance, you'd have a very convincing area light fake.
Can the new Python in Poser 8 (wxPython?) be used to do something like that or even to make new light types?
I'm not sure if the Python is on the level of an SDK or less powerful.
MikeJ ( ) posted Thu, 20 August 2009 at 3:27 PM
Speaking of which, why don't they make an SDK for Poser already?
bagginsbill ( ) posted Thu, 20 August 2009 at 3:29 PM
Quote - If you can somehow get it where the shadow is sharp near where the ball touches the floor, then blurs more with distance, you'd have a very convincing area light fake.
Mike, look closer at my last set of posts. The ball is on the ground. Shadow blur near the ball is much narrower than at the apex. This has always been the case with Poser RT shadows. It is why we use them more. But the grain was always a problem. Now it isn't.
I'll do a cylinder next to show it more clearly.
bagginsbill ( ) posted Thu, 20 August 2009 at 3:32 PM
Here is a tall cylinder.
MikeJ ( ) posted Thu, 20 August 2009 at 3:47 PM
That looks better, much better.
But the shadows on the ball don't look right, in terms of distance, like it seems there should be more shadow under the ball than there is.
pjz99 ( ) posted Thu, 20 August 2009 at 3:50 PM
This is the major advantage of raytraced shadows with blur vs. depth mapped shadows (where the whole shadow is uniformly blurry).  The reason the ball's looks the way you notice is that he's rendering with a purely raytraced shadow, and no form of ambient occlusion or GI.
My Freebies
bagginsbill ( ) posted Thu, 20 August 2009 at 3:58 PM
Another demo, this time with one spotlight with BRTS, ISF, IDL, HSVETM - every P8 trick.
BRTS = Blurred Ray Traced Shadows
ISF = Inverse Square Falloff
IDL = Indirect Diffuse Lighting
HSVETM = Hue, Saturation, Value Exponential Tone Mapping
Render time 1 minute.
ice-boy ( ) posted Thu, 20 August 2009 at 4:00 PM
he used a very extreme angle on the light.
but he did good because he needed to show how the samples work.
ice-boy ( ) posted Thu, 20 August 2009 at 4:02 PM
Quote - Here is a tall cylinder.
yes yes yes
i need this . when is SP1 going to be realesed?  lets say month. november? is november a realistic date?
