Sun, Nov 10, 1:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
Subject: Help with V4 Bodysuit
hbaioni ( ) posted Fri, 14 August 2009 at 1:19 PM · edited Thu, 25 July 2024 at 6:31 AM
Hey guys, i need your help. I have two questions:
  1. As you can see in the attached image, i have a problem with V4 bodysuit. Check out the bottom of the t-shirt, and you'll notice it's sawed. I used one of the build-in bodysuit forms. But, as soon as i apply the morphs (in this case, it is v4 elite) the border gets like this. Perhaps i should use a trans-map instead of the build-in template?
  2. I want to make this border (the bottom of the t-shirt) more volumetric. I tried using a bump map, but it does not achieve the effect i desire. I want the t-shirt to look real, and for that purpose i need to enhance all the borders. (the borders in the arms and in the belly). Otherwise, the whole t-shit will look like this... like an akward bodypaint.
hemi426 ( ) posted Fri, 14 August 2009 at 4:13 PM
I think it could be done with a transmap and a bumpmap. I've attached a quick and dirty test. At the lower hem of the shirt there's a bumpmap applied. Simply three lines next to each other, the middle one is a dotted line.
hernan75 ( ) posted Fri, 14 August 2009 at 10:20 PM
Well... i did what you suggested. I used a transmap and did a quick render. The problem is that it works only if you use the standard V4 figure. As soon as you apply the morph, the t-shirt gets deformed.
Does anyone know a way to prevent this?
hemi426 ( ) posted Sat, 15 August 2009 at 2:36 AM
You could now adjust the transmap to compensate the distortion. It's a bit of try and error process.
markschum ( ) posted Sat, 15 August 2009 at 9:56 AM
Yup, as soon as you apply morphs the vertices move from the position used to generate the uv map.  Using displacement rather than bunb might get you a better looking edge. It will show better from most angles.
