Sun, Nov 3, 5:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
Subject: Double Icons in Library - Poser 8
Daventaki ( ) posted Mon, 24 August 2009 at 5:54 PM · edited Tue, 29 October 2024 at 7:01 AM
I am getting duplicate item icons on a bunch of my runtimes.
IsaoShi ( ) posted Mon, 24 August 2009 at 6:25 PM
It's a known P8 bug. If you refresh a second time, it should correct itself.
It should be sorted in SR1.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
pjz99 ( ) posted Mon, 24 August 2009 at 6:26 PM · edited Mon, 24 August 2009 at 6:26 PM
In all categories, or in the Materials folder?  This is something that can happen in the Materials folder, if you have a Materials File (.mt5) and a Materials Collection (.mc6) that have the same filename, but I don't think it should happen anywhere else.
edit: or that ^^
My Freebies
nruddock ( ) posted Mon, 24 August 2009 at 6:28 PM
Quote - I am getting duplicate item icons on a bunch of my runtimes.
Most likely reason is that you uncompressed the files and kept the originals.
pjz99 ( ) posted Mon, 24 August 2009 at 6:36 PM
Ah that's a good point (*.cr2 and *.crz for example).
My Freebies
grichter ( ) posted Mon, 24 August 2009 at 7:35 PM
 Once and a while I have to do the double refresh trick posted by ratscloset and as mentioned above. I only see it when adding new content and doing the first refresh. Never on a complete restart of poser.
Sort of OT: Older daz content does not come with jpg's. P8 will not generate them on the fly like P7-PPro does. If installing new -old daz content without icons, just touch the folder with an older version of poser and you are good to go in P8 (unless it is masked by an alpha channel which is a common issue on old daz Mac content)
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
bagginsbill ( ) posted Mon, 24 August 2009 at 9:15 PM
Hover over the duplicates and compare the file names. If you see identical filenames, then it is a bug. If you see the compressed and uncompressed versions of the same files, remove the duplicates, because they are real.
grichter ( ) posted Mon, 24 August 2009 at 10:28 PM
Quote - Hover over the duplicates and compare the file names. If you see identical filenames, then it is a bug. If you see the compressed and uncompressed versions of the same files, remove the duplicates, because they are real.
BB it is a known Bug. Ratscloset posted words to that effect over a week ago and the second refresh trick.
Gary
bagginsbill ( ) posted Mon, 24 August 2009 at 11:20 PM
Thanks, GR.
Daventaki ( ) posted Tue, 25 August 2009 at 12:39 PM
Thanks everyone,  next time i see it i will do another refresh.
