Sat, Feb 1, 5:22 AM CST
Renderosity Forums / Poser Python Scripting
Welcome to the Poser Python Scripting Forum
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
We now have a ProPack Section in the Poser FreeStuff.
Check out the new Poser Python Wish List thread. If you have an idea for a script, jot it down and maybe someone can write it. If you're looking to write a script, check out this thread for useful suggestions.
Also, check out the official Python site for interpreters, sample code, applications, cool links and debuggers. This is THE central site for Python.
You can now attach text files to your posts to pass around scripts. Just attach the script as a txt file like you would a jpg or gif. Since the forum will use a random name for the file in the link, you should give instructions on what the file name should be and where to install it. Its a good idea to usually put that info right in the script file as well.
Subject: Morphs from a directory
sixus1 ( ) posted Mon, 24 August 2009 at 11:20 PM · edited Tue, 23 July 2024 at 2:18 AM
Wouldn't it just plain rock to have a script where you could point Poser to a directory full of obj's for, let's say a head, and have it load all those as morphs? -Les
LaurieA ( ) posted Tue, 25 August 2009 at 12:11 AM
That would be flippin' awesome ;o).
semidieu ( ) posted Tue, 25 August 2009 at 2:36 AM · edited Tue, 25 August 2009 at 2:37 AM
file_437919.txt
Here is a little version (it's a modification and has not been tested... so I hope I didn't made any mistakes). Save it somewhere (don't forget to change the extension from .txt to .py)
Select tha actor you want to morphs to be loaded.
Run the script (File-Run python scripts) or save it in your ScriptsMenu.
It will ask you for a folder... select the one containing the obj.
And wait... do NOT touch Poser until you have the final message.
Basil
sixus1 ( ) posted Tue, 25 August 2009 at 8:50 AM
Thanks! Gave it a shot just now and got this error:
Traceback (most recent call last):
  File "S:ModelsPythonScriptsimportMultipleObj.py", line 53, in ?
    actor.SpawnTargetFromGeometry(geom, objsName[i])
NameError: name 'objsName' is not defined
This could be a really handy script, so if you can help debug this, it would rock! -Les
markschum ( ) posted Tue, 25 August 2009 at 9:54 AM
very nice semidieu, mines not so elegant. :)
sixus1 ( ) posted Tue, 25 August 2009 at 10:57 AM
Hey there... looking further into that error, it seems like maybe there needs to be a function defined that gets the name of the obj and passes it to Poser when the morph is created. Maybe something like that is in there and I'm just not catching it, but that seems to be the kind of thing the error is related to. FYI: I'm no programmer so I'm just spitballing from my effort to trouble shoot this. I really, really want to get this script working because I know it will become invaluable for me. -Les
semidieu ( ) posted Tue, 25 August 2009 at 1:12 PM
file_437951.txt
Sorry, my fault... I edited a part of another of my script and thought I removed everything related.
This one should work...
sixus1 ( ) posted Tue, 25 August 2009 at 1:59 PM
Dude! Brilliant! Love it! This is great stuff. Just made my life a lot easier. -Les
semidieu ( ) posted Tue, 25 August 2009 at 2:01 PM
Glad you will find it useful :)
LaurieA ( ) posted Tue, 25 August 2009 at 5:09 PM
Many, many thanks sir ;o).
semidieu ( ) posted Wed, 26 August 2009 at 6:34 AM
You're welcome :)
odf ( ) posted Tue, 01 September 2009 at 7:29 AM · edited Tue, 01 September 2009 at 7:32 AM
Online Now!
semidieu: Nice work! I have just one tiny question. Lines 46 and following read like this:
            for a in
poser.Scene().Actors():<br></br>
        if not a.Name() in
curList:<br></br>
            prop =
poser.Scene().CurrentActor()
    if prop != None:<br></br>
        # GET THE GEOMETRY<br></br>
        geom = prop.Geometry()<br></br>
        # LOAD MORPH TARGET<br></br>
        name =
os.path.splitext(os.path.split(fp)[1])[0]<br></br>
actor.SpawnTargetFromGeometry(geom, name)<br></br>
prop.Delete()<br></br>
That's confusing me. Why not just write:
            prop =
            if not
prop.Name() in curList:<br></br>
        name =
Also, is there a reason one has to fill curList each time the loop is executed?
Sorry if these are dumb questions. I have no experience with the Poser API and I'm trying to learn.
markschum ( ) posted Tue, 01 September 2009 at 8:50 AM · edited Tue, 01 September 2009 at 8:52 AM
The relevant cod is thls:
for a in poser.Scene().Actors():
        curList.append(a.Name())
imExObject.Import('obj', 'File Format Wavefront', fp, imoptions)
prop = None
        if not a.Name() in curList:
                   prop = poser.Scene().CurrentActor()
this appears to do:
  build list of actors in scene
  import the obj file
  loop through actors looking for the new one thats not in the list
  allocate it to prop variable
I do wonder about that code if my interpretation is right
I would have expected to see prop = a     rather than prop=poser.Scene.CurrentActor()
The curlist needs to be refreshed before the next import if you are using it to identify the imported obj.
Please correct this if I am reading it wrong.
you need to test existance before referring to a value
prop.Name() will throw an error if prop is None.
odf ( ) posted Tue, 01 September 2009 at 9:10 AM · edited Tue, 01 September 2009 at 9:12 AM
Online Now!
If the import fails, won't "currentActor" just be whatever it was before? In that case, wouldn't it suffice to compare its value before the import with the one after the import? If on the other hand it is set to None after a failed import, that's even easier.
But maybe the code was written the way it is because it's possible to have a successful import that doesn't change the current actor. In that case, the line that now reads "prop = poser.Scene().CurrentActor()" should indeed be "prop = a".
I feel a bit weird asking questions like that, but since the API is so badly documented, I figure picking people's brain is the most effective way to understand those details.
markschum ( ) posted Tue, 01 September 2009 at 11:49 AM
I thought about this and realized he is simply testing for a successful load.
The last loaded item IS the current actor .
**semidieu certainly knows what he is doing when writing scripts. Its certainly worth asking if you dont understand something, its how you learn. Different people have different styles to their code so you need to work out your own.
It might be possible to put a try:   import  except:  display error   on the import. I dont remember if you get a trappable error.
semidieu ( ) posted Tue, 01 September 2009 at 3:43 PM
file_438511.txt
Hi!
You are right... there is a little error.
should be:
prop = a
In fact, why I'm doing that: In 99.99% of the case, the last loaded prop become the currently select prop. So doing the loop to check which actor is the new one is only for some special case (I don't know how to reproduce it, but it happens once...): if I recall well, if you click somewhere exactly after the OBJ has been loaded, the selected prop won't be the correct one...
Notice that I could optimize the code (not resetting the CurList for example):
markshum: thanks for what you said... :)
markschum ( ) posted Tue, 01 September 2009 at 3:55 PM
you need to keep updating curlist as each morph geometry is loaded (unless it gets removed as part of the morph creation)
Its nit a major overhead in this case.  It is the sort of thing to look for when your program is running really slowly.
odf ( ) posted Tue, 01 September 2009 at 5:36 PM
Online Now!
Thanks, semidieu! That explains it.
markschum: Agreed! Updating curlist after each import isn't a big performance hit in this case, and makes the code potentially more robust. But since the loop is so very simple and the newly imported prop is removed each time, I'd personally be inclined to keep it out of the loop in order to make the logical structure clearer. So I guess my question was whether there was some compelling reason not to that.
It happened to me more than once that I looked at old code of mine, wondered  why I had done a simple thing in such a complicated way, simplified the code, ran into errors, and then realized why I had done it the way I did. :laugh:
