Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
I'm a soon to be Poser user, (shipment enroute) so technically I can't help you at the moment, but this link is to Talk Designer Assistant plugin which might interest you. On the same page there are also a couple of short video tutorials that might help as well. I received the ad for it from CP.
http://www.contentparadise.com/productdetails.aspx?id=12805
HTH
Musikman
Hello
I am starting to work with the talk designer in poser pro only to find it doesnt work. I select a poser scene and then select the figure. I go to file/import/lip sync and select the sound file which is supposed to open the talk designer and it doesnt. If I click directly on the talk designer nothing happens.
Any suggestions and thank you.
