Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
Phil
For some reason I cannot seem to get this technique to work correctly For example
Is the camera you created a dolly camera? The main camera is a rotating camera that react differently then the dolly one.
Quote - Mark is correct, you can't get the same results copying an Aux Camera to a Main Camera because they don't contain the same characteristics and behaviours.
The above is not correct. The Main and Aux cameras are exactly the same apart from their name. Or at least that is true from P4 through P6, and I can't see it having changed since. Although the Main and Aux cameras are the same, many cameras do differ.
It's precisely because some cameras are different (main and dolly, for example) that it would be nice if there were a way to paste data between them. I don't know how many times I've wanted one camera type to be where the other is because of the control options available only to have to do it manually. Sometimes that is either very difficult or even impossible (impossible if you are inside a set whose walls/whatever) keep obstructing your view, making navigation problematic).
Quote - > Quote - Mark is correct, you can't get the same results copying an Aux Camera to a Main Camera because they don't contain the same characteristics and behaviours.
My bad! I stand corrected.
Thanks all for your input...
Well for some reason (reboot???) I can get all but the cameras now to work except for copying and pasting the 'created' aux cameras from the object menus. They will recieve a copy from the 'Main Camera" but you cannot paste from an created **"aux 1 (revolving)" ** camera from the object menu to any of the default poser cameras. I guess I will just not use the create cameras as a source..
Is anyone aware of a technique or script that will transfer one cameras view to another without having to manually cut and paste the data. Simular to what the assign camera does in other graphics programs
