Mon, Feb 17, 9:20 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 6:51 am)
Subject: More Conforming Trouble
GaryChildress ( ) posted Sun, 25 April 2010 at 3:53 PM · edited Tue, 04 February 2025 at 12:53 PM
I've been working on some socks to upload in the Freestuff area. After all the problems I've had with a coat I've been working on, I figure socks would be a lot less problems. So I started workingo n them and put the coat aside. Little did I know!
I loaded the Michael 4 blank figure into a scene, lined up the socks as best I could to the shins and then went into the Setup room. Again I loaded the Michael 4 Blank figure, this time into the setup room. I selected the sock (I'm doing them one at a time to simplify things I thought) then clicked on the auto group button. Sure enough the sock grouped perfectly to the shin. No facets of the sock grouped to anything other than the shin I was working on. So far so good.
Now I exit the Setup room and behold...when I try to conform the socks to the shin this is what I get!  :(
Please visit My 3D Freebies
Thank you for your patronage!
ice-boy ( ) posted Sun, 25 April 2010 at 4:44 PM
select the socs and under edit ''zero figure''
PhilC ( ) posted Sun, 25 April 2010 at 6:03 PM · edited Sun, 25 April 2010 at 6:04 PM
Import the M4 OBJ file with none of the import boxes selected, then do the same for the socks OBJ which if you have saved the new Socks figure will be in the same folder as its CR2 file.
Do they perfectly line up? If they do not you'll need to address that now.
If they do line up select the socks and turn off the IK chains.
Open the joint parameter window and zero the figure.
Select the socks hip and zero the translations. They may already be zero but best to check because the zero figure button will only zero the rotations.
Select the socks BODY and check that all translations are zero.
The socks should now fit the figure.
Next, go to Edit > Memorize > Figure. This will lock this zero state into the socks figure file. Save the socks back to the library.
If you miss this last step you'll be back to square one the next time you load the socks.
