Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 07 3:03 pm)
That didn't help either. But I got them working mostly the way I want them to. Thanks :)
LukeA
Hey Luke
Are your buttons physically joined to the mesh?
If they are then adding them to the Rigid decorated group will do more or less nothing :) they will just behave the same as the main cloth group.
The rigid group (and the soft) can't be connected to the main cloth in any way, took me a while to figure that one out :)
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
I did not know that! thanks
TemplarGFX
3D Hobbyist since 1996
I use poser native units
Quote - I did not know that! thanks
It's a bit odd isn't it, it almost seems counter intuitive to have them seperated from the main mesh :)
John
Didn't someone post a trick for dynamic chains where you'd have one big (invisible) polygon for every link and that'd help to keep the links rigid? If so, a single poly for the button would do the trick as well.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
SVDL's Blouse pack has a single poly joining the buttons onto the shirt, and those buttons stay rigid (although not rigidly in place, just in shape)
TemplarGFX
Not sure how svdl does it, but I stick by my original post :) I have been making dynamic cloth with rigid and soft decorations for a while now, and keeping the decorated parts seperate from the main mesh works.
I'd have to look at svdls blouses to see what he is up to ;)
John
John
Quote - Had a quick look at scdls blousepack from freestuff, the buttons I looked at are completely seperate from the main mesh.
John
Yeah that's how I had to do it in the blouse I just released into the marketplace too. In fact, having the pins/threads of the buttons sticking into the fabric actually caused my Poser 8 clothroom to crash! So some space between is definitely a good idea. :)
Quote - > Quote - Had a quick look at scdls blousepack from freestuff, the buttons I looked at are completely seperate from the main mesh.
John
Interesections with the main cloth are not fatal on my machine, but they are not ideal :) I find as long as the button is close to the cloth things usually work ok, though it will poke through the base cloth in certain extreme poses.
John
I find that when I create a set of buttons (and yes they are rigid decorations) they squish and distort at some point. Isn't the whole point of them to keep their shape? How can I prevent this squishing of the button mesh?You can see in the image they start out round and end up oval.
Thanks
Luke
LukeA
My latest novel
