Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Was Poser Pro open while you installed V4? If so then hit the refresh button on the library tab or just close and restart PP! If that doesn't work you may want to check your Runtime folder to ensure you installed there correctly.
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
You can check the path of your Poser library folders by hovering over an item in the library - if hovering doesn't show the path, change the library options so that it does . As ghelmer said... make sure you install V4 into the runtime that shows up there.
what I should be."
Murakami)
Poser 8 & Prose Pro 2010 both have the option to store the main runtime outside the program folder, somewhere in your documents folders, I forget exactly where as I chose to include it in the main install folder, Windows 7 & Vista also make installing to the Program files folder troublesome.
Do a search in your documents for Runtime, if it's there you'll have to add it as an extra runtime in the library screen so Poser can see it.
Windows 7 64Bit
Poser Pro 2010 SR1
I just installed Poser Pro 2010 and everything seems to have gone well, but when I try to install Daz's V4, it goes in alright (I think) but when I open Poser Pro, it isn't in the libraries. Any help would be appreciated. Thanks.
