Sun, Feb 16, 2:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: V4 Pose problem
xpdev ( ) posted Tue, 28 September 2010 at 8:44 AM · edited Fri, 19 July 2024 at 3:27 PM
I manually created a position for Victoria (Vic)
Then I load a new Victoria (Vic_1).
How can i duplicate the Vic pose to Vic_1 without having to re-create by hand ?
Many thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
geep ( ) posted Tue, 28 September 2010 at 9:03 AM · edited Tue, 28 September 2010 at 9:06 AM
Use the Pose Dots. (See the UI Dots?) ...
... Click the little arrowhead and select "Pose" Dots and then ...
When Vic is posed ... Click on 1 of the 9 Pose Dots. (It will turn orange)
Now load Vic_1 ... then click on the Pose Dot you clicked on for Vic  to load the Pose you saved.
cheers,
dr geep
P.S. You only have 9 Pose Dots and if you need to clear one, hold down the "Alt" key and click on the Dot you want to clear.
cheers,
dr geep ... :o]
edited 10/5/2019
xpdev ( ) posted Tue, 28 September 2010 at 9:07 AM
Many thanks, i try....
markschum ( ) posted Tue, 28 September 2010 at 10:27 AM
The other way is to save the pose into your pose library. Use the + button and follow the prompts. The pose library is a permanant copy unlike the pose dots.
