Sun, Feb 16, 9:34 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: When using Carrara's 3D paint, can one constrain the cursor to V or H?
Plutom ( ) posted Tue, 28 September 2010 at 3:24 PM · edited Mon, 10 February 2025 at 10:35 PM
Hi guys, I'm trying to paint (using 3d Paint in the assembly room) a straight line horizontally across a vertical cylinder and I'm doing about as nice of a job as painting a trim around the top of a wall (meaning it slops all over the place).  Is there a constrain function that I can use to lock the cursor either in the horizontal or vertical mode?  Jan
MarkBremmer ( ) posted Tue, 28 September 2010 at 4:37 PM
 In 3D painting there are no constraint properties. For precision like that, it would be best to open up the texture map in a paint program, do the constrained work, and then re-import it back into Carrara for the organic painting.
Plutom ( ) posted Tue, 28 September 2010 at 4:51 PM
Thanks Mark, I was afraid of that--Jan
mmoir ( ) posted Fri, 08 October 2010 at 8:26 PM · edited Fri, 08 October 2010 at 8:27 PM
You can use the line tool and constrain that to horizontal or vertical using "Ctrl" or at least I think it is the  "ctrl" key.
Mike
Plutom ( ) posted Fri, 08 October 2010 at 9:14 PM
Hi Mike,  thanks, that works---Jan
