Thu, Dec 12, 2:28 AM CST
Renderosity Forums / DAZ|Studio
Welcome to the DAZ|Studio Forum
Forum Moderators: wheatpenny Forum Coordinators: Guardian_Angel_671, Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 09 1:48 pm)
Subject: Can anyone tell me
  • 1
  • 2
Miss B ( ) posted Sat, 20 November 2010 at 1:05 AM
Quote - When I'm creating promos, Vex lights are my goto lights.  Renders are done quickly with a professional look.
Where would I find the Vex lights?  Are they here in the RMP?
_______________
Butterfly Dezignz
tokejr ( ) posted Sat, 20 November 2010 at 4:58 AM · edited Sat, 20 November 2010 at 4:58 AM
Attached Link: VexLights
> Quote - > Quote - When I'm creating promos, Vex lights are my goto lights.  Renders are done quickly with a professional look. > > Where would I find the Vex lights?  Are they here in the RMP?
Here ya go:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=68449&keyword=vexlights
Miss B ( ) posted Sat, 20 November 2010 at 8:18 AM
Thank you very much for the link.  😉
_______________
Butterfly Dezignz
tokejr ( ) posted Sat, 20 November 2010 at 8:31 AM
Quote - Thank you very much for the link.  😉
You're welcome.  They're very versatile lights.
DustRider ( ) posted Thu, 25 November 2010 at 10:56 AM
If you have DS3A, the included UberEnvironment lighting might give you the results you are looking for. I found it extremely easy to set up. This image was my  first attempt at a "portrait" with DS3A, for a rank DS noob, with very little set up, I think came out fairly well (I usually use Carrara). If interested, you can see the full image (Blue Girl) in my gallery at:
http://www.renderosity.com/mod/gallery/browse.php?username=DustRider
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
rebelmommy ( ) posted Thu, 25 November 2010 at 11:34 AM
DustRider, that is an awesome image!  I do have DS3A however I think wrapping my brain around the lighting differences is what is causing me issue.  I really think that DS has a superior lighting system however when you are used to one way often switching to another ends up being more complicated then it should be :(
Renderosity's "problem Child"
Support Hydrocephalus research.. because a Shunt is NOT a cure!
DustRider ( ) posted Thu, 25 November 2010 at 1:50 PM
rebelmommy wrote:
Quote - DustRider, that is an awesome image!  I do have DS3A however I think wrapping my brain around the lighting differences is what is causing me issue.  I really think that DS has a superior lighting system however when you are used to one way often switching to another ends up being more complicated then it should be :(
Thanks! That's an awesome compliment comming form you (I'm a big fan of your work)! I agree wth you 100% about lighting in different software. Lighting in Carrara has always been easy for me, but until I got Poser 2010 I couldn't get anything I really liked out of Poser.
DS was the same, only worse than Poser for me, until I got LightDome Pro (pre DS3). It helped a lot, but I still wasn't able to get images I really liked out of DS2x. DS3 changed that. With DS3A I was able to get a good outdoor scene with LightDome 2 Pro, so I thought I would try UberEnvironment since in the DS forums over at DAZ people thought it was great. For me, it was almost like the elusive "make art" button for a photo studio style render. The image above was literally my first attempt with UberEnvironment 2. Including test renders, which I usually tend to render at higher settings than needed, the total tme to figure out UberEnvironment 2 and set up the lighting for the final image was less than 1.5 hours (working on a laptop while watching TV with the family).
If this is close to the render style you are looking for, I'd highly recommend giving it a try. If memory serves me properly, I think you could use Render Throttle (available at DAZ) to speed up renders with UberEnvironment.
rebelmommy ( ) posted Thu, 25 November 2010 at 1:55 PM
Good to know.. I actually have Render throttle and LightDome Pro so guess it is just a matter of me delving into DS and making the attempt :)
DustRider ( ) posted Thu, 25 November 2010 at 3:13 PM
I have two other images in my gallery done with LightDome 2 Pro. The link below is to a thread here about the first one - Afternoon Walk. There is a bit of information in the thread about the LightDome 2 Pro settings I used. It was a bit of a challenge to light properly with a light dome because I used the Millennium Environment, which has some odd shadows, and tends to block back light.
Good luck with DS - I'm sure you'll get the lighting under control very quickly :-)
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2790249
  • 1
  • 2
