Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Also check your Poser General Preference (misc tab) is not using External Binary Morph Targets - that will cause the import to loose all pose and morphs.
LVS - Where Learning is Fun!
Could be problems with external runtimes? Try to use the Poser script CollectSceneInventory. That saves everything to a folder - included textures, obj files, etc.
It can't be a bug as there are many of us who import Poser items daily without any problems.
I'm not an e-on fanboy like some on here but I can't say it's Vue's fault, I think you should be looking elsewhere..
It's difficult to offer advice without knowing a ton of info that you prolly can't supply because of where we all are in the world..
Injustice will be avenged.
Cofiwch Dryweryn.
vue 8 never worked well for importing conformed figures, particularly or maybe only when the item had conformed to scale checked did it not work. However in vue 9 my importing woes are over. All is good now.
Love esther
If you do a lot of importing ito poser Vue 9 will be worth it just for that.
Well i have imported 200 varoius characters and props into vue 8, loads of them have major import problems.
I create in poser pro 7, 8 or whatever ya using, then load into poser 6, save the figure scene or whatever in poser 6, imports into vue 8 all correct.
It is down to E-ON again, to bloody lazy or no brains to even make pro 2010 import into 8 correct.
If vue 8 accepts from vue 6 then not properly from pro 2010 then it is lazy programing from E-on.
Be easier if they give it to non yank programers so they can show them how to program a PC properly.
Even after 30 years non american programers still sorting out thier faults
yes, they should have fixed it all for previous versions. But i can tell you that vue 9 is very much better. Less crashes, less memory leaks, and imports poser pro 2010 really well even when conform to scale is used on the clothing.
Love esther
I'm finding imported Poser figures are losing their morphs and confomed figures (hair etc) are out of place.
I'm using Vue Complete 8 & Poser 2010.
Anyone else run into this?
