Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Quote - try right click on poser.exe and set to run as administrator, then see if you still have a problem.
The problem still remains, I even uninstalled then reinstalled as an admin tried installing with the default content path, then reloaded the program as an admin and it still shows up. Starting to wonder being I only paid $52 for the Black Friday upgrade SM sent me a $52 not fully working version :)
Thanks for the ideas everyone. Seems like I'll have to take this one up with SM.
Thanks, but the Python shell window won't even open.
Guess I need to do some more digging, I tied installing it on my laptop and had no problems. SM said that the python already installed should'nt affect it but I might try to uninstall it just to make sure. and to try rebooting windoze in diagnostic mode and see what happens
I had some issues with Python, same error message, Windows 7. Using import wx on the Python command line shell got me this:
Python 2.6.2 (r262:71605, Apr 14 2009, 22:46:50) [MSC v.1500 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
import wx
Traceback (most recent call last):
File "", line 1, in
ImportError: No module named wx
Here is the reply I received from SM... I've looked over the link they provided and cannot make heads or tails of it... any ideas anyone?
This has to do wth the Python Environment Variable. Here is a link with more details.
http://docs.python.org/using/windows.html
You need to set the Preference to the 2.4 Version. You should be able to have multiple variables set. I was told the issue is Blender Installer sets the Global Environment Variable for Python to the version it installs. If the ENV has multiple entries, try switching 2.4 to the front.
Let me know if you have any questions. I am downloading Blender now to see if there are any settings in Blender to allow you to resolve this from there.
If you do have environment variables referring to the Python Blender uses, then the simplest solution is to create a batch file for launching Blender, add the relevant SET commands for the env variables and then remove them from the global environment.
Which version of Blender are you using (I'm guessing 2.49 as that uses Python 2.6) ?
Perhaps more importantly, are you using the 32-bit or 64-bit version ?
If you're using the 32-bit version, are you using the installer or the ZIP ?
Quote - If you do have environment variables referring to the Python Blender uses, then the simplest solution is to create a batch file for launching Blender, add the relevant SET commands for the env variables and then remove them from the global environment.
That went way above my head, anything going past double clicking is beyond me. Is there a tutorial somewhere for me to try to follow?
Thanks
Hi, as like several others I've just upgraded to Poser 8 with the Blackfriday special and received an error as well. My error seems different and I can't seem to find any posts on it yet.
This is what I get anytime I launch Poser: Error importing the wxpython api
That error showed up before I installed the sr3 update and still does.
I'm not sure if it matters or not but I do have Python2.6 installed to work with Blender.
Any ideas?
Thanks
