Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 04 1:34 pm)
Line 117 of the file Poser.xrc looks like this:-
Duplicate &Object/Figure
If you edit it to say:-
DuplicateXXX &Object/Figure
Poser will continue to display the label as "Duplicate". This along with the fact that the selected actor/figure name always appears in the label name leads me to think that the command is encoded into Poser elsewhere. The line in the xrc file may just be a place holder.
So taking a leaf out of McGiver's book; "Plan A is to always have an outstanding Plan B". Here is plan B.
In Notepad write:-
import poser
poser.ProcessCommand(1568)
This Python script will execute the same command as the Duplicate menu command. Now here is the clever bit. Save the file in Poser 8:Runtime:Python:poserScripts:ScriptsMenu with the name Duplicate###Ctrl+Alt+D.py
Now type Ctrl+Alt+D and it will run the script, which will fire the command, which will duplicate the actor/figure. Ctrl+Alt+D is not used anywhere else as a shortcut.
Works for me :)
Hope that helps.
I do have no idea about XML files but I found there something like this inside one of them ("roomTabs.xml):
<Widget name="faceRoomTab" command="9003" ...
so I thought it could be used in the same way like "poser commands" to assign shortcut to it via python but it didn't work.
Do you know if there is a way to make it work? (if it works then we can navigate between windows with shortcuts)
I belive that this "9003" is some kinf of command for displaing Face Room.
For material Room the number is 9002 but the one from poser.xrc file is 1265
What you need Adom, is on page 232 of Python for Poser.
import poser
poser.Rooms()[2].Show(1)
Python for Poser goes into a lot more detail and explanation of how it works. Plus it draws your attention to some apparent typos in the manual supplied with Poser which could be very frustraiting if not drawn to your attention.
hi,
Could anybody try adding shortcut to "duplicate" command and share the result?
I just cannot make it work:( -> poser 8
thanks.
