Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2025 Jan 04 3:16 am)
skiwillgee.
Unfortunately, even using the Wayback Machine to access what's left of Richard Vanlippe's website, the quicktime of the animation just refused to load.
I was going to follow the tutorial through to the end and produce (hopefully) an animation but I've been a bit busy lately.
I don't suppose anyone else has a copy of the original animation????
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Yes, that's what I'm going to try today. Let's all have a go! It'd be great to see what everyone's efforts look like.
Measure
your mind's height
Rendered all night but found I'd forgotten to animate the upper section of the falls ggg!
Trying again.
Measure
your mind's height
Not too bad actually, it's slow rendering the full version, mainly because I'm trying to render a version of my entry for the Bryce challenge at the same time... Good job I've got a quad core PC!
So how's your attempt at this coming Peedy?
Measure
your mind's height
I certainly hope you do, I found the tut to be pretty simple, and have now finished rendering the animation result (popped a few sounds on to finish it off,) and it's now on the last page of the tutorial - at the very bottom.
http://www.franontheedge.com/animating_vanlippes_waterfall.html
Measure
your mind's height
Thanks, peedy, clay, skiwillgee.
So.... where's the next waterfall animation guys n' girls?
*poke, poke, pokey!
Measure
your mind's height
Corrie,
Why not? Do you need any help? I'd be happy to help if I can.
Measure
your mind's height
Quote - No, thanks, Fran.
I think one of my biggest problems is that I don't have any interest in doing animations.
I love watching it, but doing? Nopes.I did make a lovely scene, including the waterfall, though. :-)
Will post it next Friday.Corrie
Oh I see. Having done a course in animation, I just think that way, but each to their own.
I look forward to seeing your render of the scene though.
Measure
your mind's height
Here's the link to my image:
http://www.renderosity.com/mod/gallery/index.php?image_id=2178917
Corrie
Whooooo! that's a high waterfall!
How come all of the image apart from the two birds on the log is a blue cast?
Do you use a blue haze?
Those 2 birds certainly stand out. Did you make the bird model yourself?
I tried to find some bird models for my waterfall without much success, although how I would have animated them, I don't know.
Measure
your mind's height
I love high, big waterfalls.
Never have seen one for real, but this is one of the ideas I have of them. :-)
The blue is from the sky and lighting.
And yes, a blue haze.
I don't know why the birds didn't get the haze, too.
All animals are from 3d Meshed:
http://www-roc.inria.fr/gamma/gamma/download/download.php
I don't know if their models can be animated.
Corrie
Quote - I love high, big waterfalls.
I have and actually it was a lot smaller, and a lot higher than the Vanlippe waterfall.
Quote - The blue is from the sky and lighting.
Ah, I thought it was, I'm not too keen on using haze, so much so that I've saved a default.br7 file with both haze and fog turned off, so that I don't have to keep on turning it off every time I open Bryce.
I like the birds.
Quote - All animals are from 3d Meshed: http://www-roc.inria.fr/gamma/gamma/download/download.php
Anything can be animated if you can rig it. Thanks for the link, but I can't figure out how to download from there. Pity as it's the only place I've seen so many birds. Probably you have to pay to join or something.
Aha! No, I found one that COULD be downloaded.
Oh.... no textures. Bryce doesn't like it.
How on earth did you manage to get a properly textured bird into Bryce?
Measure
your mind's height
Sometimes I like a lot of haze.
It looks good in this image.
But usually I don't use that much, either.
No, no textures.
From some objects you can select different parts, so you can put different mats on.
Others don't have that option and I just put on a mat that's close to what I want.
Usually you can get a lot done with the objects, though.
And yes, the site is free as are the downloads. :-D
Look for the obj and 3D ones.
They can be dowloaded, as far as I know.
And if you use 3dMax, they have for that program, too.
Corrie
Quote - Sometimes I like a lot of haze.
But usually I don't use that much, either.No, no textures.
Usually you can get a lot done with the objects, though.And yes, the site is free as are the downloads. :-D
And if you use 3dMax, they have for that program, too.Corrie
Ah right, I'll keep looking then. No I don't have 3ds Max but sometimes that format works better than .obj does in Bryce.
By the way, I meant to ask you - did you use the terrain image that came with the tutorial for your waterfall or did you actually paint your own terrain? (Either in Bryce's terrain editor or in a paint/draw prog like PhotoShop?)
I ask because I tried making a terrain from drawn greys in PhotoShop, but it turned out too smooth, not stepped enough.
So for the sake of speed I reverted to using the original image from Richard Vanlippe's tut.
I just wondered if you used that too or created your own?
... come to that, I'm now wondering if the smooth one I made would actually be so bad... I never did try it out completely.
Measure
your mind's height
I know why my version of the terrain didn't initially look right, it's just that I used a soft brush to paint it, instead of a hard one - but I've been testing it out, it's not so bad.
I'll try rendering it again now that my email's sorted out - that frightened me - but it's sorted now.
I'm just finding that the 3rd terrain needs to be a little bit further forward than the others. That's the one with the drops mat on it.
Otherwise I have one terrain with a water on it (the pool mat) and one with the stone or rock mat.
Corrie, did you use 2 or 3 terrains?
I noticed that Vanlippe mentioned using 3 but I think he meant 2 with slightly different streams... not sure though.
I animated 2 terrain's mats, the pool one and the drops one.
Measure
your mind's height
Oh - snap!
Lol!
Although I didn't enlarge mine but just shifted them forward a bit.
I've also found that you can use the same technique for animating falling steam...
It might need a bit more tweeking but it did work.
Measure
your mind's height
Attached Link: Vanlippe's Animating a Waterfall Tutorial
Hi,As someone was asking about animating a waterfall, and people keep asking every so often, I am hosting Richard Vanlippe's "Animating a Waterfall" tutorial.
His site has been gone for some time now and although Zhann did host it for a while, her site is also no longer accessible.
So to keep this invaluable tutorial alive, that still works even now in Bryce7.1 (I've been testing it!), here's the link for it.
Here I've been playing with the waterfall:
It looks different to Vanlippe's as I've also been playing with the IBL, which becomes quite render intensive, if like me you like doing things as big as your screen will let you! Lol! The full size of this took a day and a night to render...
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
