Wed, Feb 19, 2:39 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 5:11 pm)
Subject: color picker
buddhanature28 ( ) posted Sun, 07 August 2011 at 9:23 AM · edited Tue, 29 October 2024 at 6:19 PM
Ok I am sure it should be obvious but I feel like I must be having a moment this morning...went to try to use the eye dropper tool in material room this morning to select a color from one group in my obj to apply it to another group and for the life of me can't understand how it works! Either its not intuitive or I am not- but I would appreciate any advice. Thanks!
geep ( ) posted Sun, 07 August 2011 at 9:34 AM · edited Sun, 07 August 2011 at 9:38 AM
It's not a "color picker" (per se) in the Material Room" ... It's a Material selector.
You can change the color of an object (after it has been selected) by clicking on the color in the "Poser Surface" area.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
hborre ( ) posted Sun, 07 August 2011 at 10:38 AM
Or holding shift+clicking the color chip for more precise settings.
geep ( ) posted Sun, 07 August 2011 at 11:02 AM · edited Sun, 07 August 2011 at 11:03 AM
> Quote - Or holding shift+clicking the color chip for more precise settings.
... Um, I believe that'd be the "Alt" or "Ctrl" key if yer usin' Win 7 & Poser 8. 😄
Or you could ... see image above. :biggrin:
cheers,
dr geep ... :o]
edited 10/5/2019
hborre ( ) posted Sun, 07 August 2011 at 12:46 PM
Oops, my bad.  It is Ctrl key,  Thank you, Doc, for the correction.
geep ( ) posted Sun, 07 August 2011 at 12:58 PM
No prob. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
buddhanature28 ( ) posted Sun, 07 August 2011 at 1:58 PM
Thanks everyone. Maybe I should be more specific. I have one wall that I want to be the same color as another wall I have already created on the object. Each  section of the wall is grouped. What is the best way to copy the color of section of the wall I like to the other sections? Thanks...H.
hborre ( ) posted Sun, 07 August 2011 at 3:25 PM
If the material zones share the same image map or procedural shader nodes, simply right-click in the empty field to open the menu, select all, and apply to all...  Otherwise, copy and paste should do it.  Now if it is a specific color regardless of the image map attached, Ctrl+click on the color chip, create your custom color, then click on the bottom button to Add the custom color to the palette.  You will need to go into each zone to make the modifications manually, but your new input will be available until you shutdown Poser.  Unfortunately, custom chips are not permanently retained between sessions.  Hopefully, this answers your question.
Rance01 ( ) posted Mon, 08 August 2011 at 5:46 AM
If you can select the 'target' material you want to use, using the eye-dropper or the Object / Material drop down menus in the Material room, than save THAT material to the library.  Using the Object / Material drop down menus to select the item you want to copy that material to.  Then load it from the library.
Hope this is clear.  It's early morning here.  I rarely use the mouse to try and select fine items.  The drop down menus contain everything in your scene ...
Best Wishes,
Rªnce
buddhanature28 ( ) posted Mon, 08 August 2011 at 8:01 PM
Oh yes that seems simple! Thank you all for your help!!! :-)
