Wed, Feb 19, 3:02 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 5:11 pm)
Subject: wallpaper problem
buddhanature28 ( ) posted Tue, 09 August 2011 at 7:20 AM · edited Thu, 23 January 2025 at 8:25 AM
Hi,
As you can see I am having a slight problem wall papering this room! I have tried adjusting the size, auto fit, and offset all to no avail. (I am also using clamped) Could anyone suggest what settings I need to get this wallpaper to load to the right orientation? The room is uv mapped with each wall and the floor...thanks! H.
bobbystahr ( ) posted Tue, 09 August 2011 at 7:41 AM
try rotating a copy of the image 90 degrees to the right[in your paint program] and using that instead
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
lesbentley ( ) posted Tue, 09 August 2011 at 8:53 AM
Try this. Set the 'Texture_Coords' to VU, and place a minus sign in front of the 'V_Scale' value'.
lesbentley ( ) posted Tue, 09 August 2011 at 9:37 AM
This also works for a tiled image, see above.
bobbystahr ( ) posted Tue, 09 August 2011 at 11:41 AM
Good post les...not a Poser user myself so I gave an outside the app answer but yours is way simpler.. ..
I see a sound
buddhanature28 ( ) posted Tue, 09 August 2011 at 10:11 PM
Thanks for the advice guys but I haven't managed to get it to work yet! I have tried every possible combination I can think of. Assuming I do get it figured out how do I sell the room with the wallpaper without having the user have to figure it out too? I wonder if there is an easier way to do this...thanks...H.
markschum ( ) posted Tue, 09 August 2011 at 10:24 PM
A material collection or mat pose should set the wallpaper correctly. If its right when  the propis saved then it will load that way as well.
Setting the UV parameter to VU should have the right effect of rotating the map 90 degrees.  Ir may be easier to  adjust it in a paint program though.
Acadia ( ) posted Wed, 10 August 2011 at 12:25 AM
Can you post a screen capture of the advanced settings in your Material Room, showing the nodes with the image opened up at the bottom of it?
buddhanature28 ( ) posted Wed, 10 August 2011 at 9:49 AM
Here is a screen shot of wall one. On this wall the settings work with UV as far as orientation (the other wall needs vu) In case you can't see the settings the closest approximation I could find to get the wallpaper to fit was:
.9 u scale .4 v scale and UV, tile
It is not an exact fit though and the border is too big, but is the closest I seem able to do! I can send you what the other wall looks like too...
Thanks for your help. H.
buddhanature28 ( ) posted Wed, 10 August 2011 at 9:50 AM
Ok here it is as big as the forum will allow! :-)
buddhanature28 ( ) posted Wed, 10 August 2011 at 9:51 AM
or at least as sized as I can figure out how to make it from my screen that the post will accept... :-)
hborre ( ) posted Wed, 10 August 2011 at 10:08 AM
Resolution and size are terrible.  If you have PowerPoint, paste the image onto a page and resize.  Save it out as a jpeg for posting.
buddhanature28 ( ) posted Wed, 10 August 2011 at 11:06 AM
Yeah I think its to do with my screen size...
I don't have power point...I tried copying it into gimp but not sure it will be any better. I will try to load now... H.
buddhanature28 ( ) posted Wed, 10 August 2011 at 11:08 AM
trying again...
buddhanature28 ( ) posted Wed, 10 August 2011 at 11:09 AM
hmm I can''t seem to get it to save and scale at anything viewable or allowable in size here. Could it be because I am using a 32 inch screen or wouldn't that effect it? Thanks. H.
markschum ( ) posted Wed, 10 August 2011 at 11:17 AM
can you go to the material room, and slect the wallpaper material , then click the button to save a material. Save a single material only. then rename it to a .txt file and post that file to the forum. ?
it will be much easier to examine the material file.
buddhanature28 ( ) posted Wed, 10 August 2011 at 12:54 PM
file_471740.txt
I hope this is what you meant let me know if it doesnt work...Thanks! H.
buddhanature28 ( ) posted Wed, 10 August 2011 at 12:55 PM
when I tried to open it- it looked liked gibberish to me! Let me know if I did it wrong? I saved the material and then I clicked on the png file that was created when I saved as a material and renamed it as a text. Thanks. H.
millighost ( ) posted Wed, 10 August 2011 at 1:44 PM
Quote - hmm I can''t seem to get it to save and scale at anything viewable or allowable in size here. Could it be because I am using a 32 inch screen or wouldn't that effect it? Thanks. H.
Actually the image seems to be quite large (1024x768), but most of it is white, perhaps you used "resize canvas" instead of "scale image" or so?
lesbentley ( ) posted Wed, 10 August 2011 at 9:20 PM · edited Wed, 10 August 2011 at 9:24 PM
Quote - when I tried to open it- it looked liked gibberish to me! Let me know if I did it wrong?
It is wrong. You posted the png file instead of the mt5 file. The png is just a thumbnail image, we need the mt5 (or mtz) file.
By default Windows hides some file extensions, and this can cause confusion, if you can't see the file extensions, go to Windows Control Panel > Folder Options, in the View tab, deselect "Hide file extensions of known file types".
buddhanature28 ( ) posted Fri, 12 August 2011 at 7:01 PM
file_471831.txt
You're right- that's what I did! Thanks for helping. I think I got it this time...
H.
markschum ( ) posted Fri, 12 August 2011 at 8:09 PM
ok, in that material file the option is still set yo UV and to turn the image 90 degrees it needs to be VU
here are two pics that show the difference, but you wont see the change in preview. Poser has limits on what its preview will manage.
markschum ( ) posted Fri, 12 August 2011 at 8:11 PM · edited Fri, 12 August 2011 at 8:13 PM
and heres the VU setting
soory the pic is not clear, go back to lesbently post to see the part to change.
markschum ( ) posted Fri, 12 August 2011 at 8:17 PM
a utility you might look at is MWSNAP. That is a screen capture utility that creates a jpg image from any window or section of the screen you specify, it will grab the entire screen or any part of it. Its much easier than PrtScrn and paste in a paint program.
buddhanature28 ( ) posted Fri, 12 August 2011 at 8:20 PM
must have forgot to change that...thanks...I have got a much better image now by changing the settings to:
.2
.2
.12
vu
tile
But the problem now is it doesn't look like the tile is lined up exactly and the border looks off in close up. I will post a pic. If anyone can help my eyes are going funny after doing this for five days!
Thanks!
bobbystahr ( ) posted Sat, 13 August 2011 at 9:10 AM
looks fine to me, don't let the perspective throw you off...all the features line up to my eyes.. ...
I see a sound
buddhanature28 ( ) posted Sat, 13 August 2011 at 6:36 PM
thanks. :-) Maybe I have been looking at it for too long! The good thing out of all this is I learned how to texture in Poser and Blender in five days!
