Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2025 Jan 04 3:16 am)
What Bryce version are you using? And please only post once. Thanks!
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
To post an image in forum:
2)then reply to this thread; plus click on "attach file" box below the text input box and browse to where you saved the image on your computer; then click "preview reply" to see if it loads okay or simply click "post reply" if you are sure of your file and text.
goofygrape
Assuming your material has only one channel, you will have the little bead lit across from the diffuse catagory in the mat lab. If so, click on the bead across from "bump" in the same column the diffuse bead is lit. This will use your same material as a bump channel. Now move the bump slider or enter a value (+/- 0-300) This will apply bump that corresponds to the dark and light colors in you material.
If you have more than one channel in diffuse catagory you can get the extra channels applied to the bump by holding down the shift key when you click on the beads in the bump catagory.
Someone correct me if I am wrong.
Hi all ,
I am trying to make an mat that look's somthing like rocky grass?
Using the DTE and so forth,the result so far almost the right colours but no bumps.
When I can figure out how to send a clip of it all,I will send the attachment .
The mat is for a ground plane mountian cover.The long cube is close to the right colour,ground plane was starting to be flowers on grass
Dont look at the hole in the cube
thanks
bigjohn(aka goofygrape)
