Sun, Nov 24, 10:24 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Poser Libraries disappeared
STRAFE52 ( ) posted Sat, 08 October 2011 at 5:37 PM · edited Tue, 30 July 2024 at 8:35 AM
I had Poser 8 on a portable harddrive, which is K: and just put it on an external drive, which is J:. Now, when I open Poser 8, none of the libraries show because the Poser 8 was previously mapped to K:. I can't rename my J drive to K drive because it would affect several programs on it, but I just need to know how to get the Poser 8 to recognize the libraries with the new drive letter. Thanks for any help.
nruddock ( ) posted Sat, 08 October 2011 at 7:31 PM
Quote - I had Poser 8 on a portable harddrive, which is K: and just put it on an external drive, which is J:. Now, when I open Poser 8, none of the libraries show because the Poser 8 was previously mapped to K:. I can't rename my J drive to K drive because it would affect several programs on it, but I just need to know how to get the Poser 8 to recognize the libraries with the new drive letter. Thanks for any help.
Fixing Poser is relatively easy, just edit the LibraryPrefs.xml file to reflect the drive change for those Runtimes that need it.
You are however going to run into problems with any files that have full paths that refer to the older drive.
The only permenant solution to those is to fix them up when you find them.
You should also make sure that the assignment of drive letter is permenant (or at least as you can persuade Windows to make it).
