Thu, Jan 9, 5:13 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
Subject: Layered image in material room
ShaaraMuse3D ( ) posted Tue, 29 November 2011 at 9:27 AM · edited Mon, 09 December 2024 at 2:22 PM
I am trying to work out how to add a transparent png on top of a base image in the material room, but can't get it to work properly. The base image is attached to the diffuse node.
I've tried using the alternate diffuse, but the png turns out all white, even though the transparancy seems to work as it should.
Is there any other way to get this to work properly?
hborre ( ) posted Tue, 29 November 2011 at 9:32 AM
You will need to use a blender node to be able to combine the 2 images.  I am not currently at my own computer, so someone will come along with the specifics on how to accomplish this.  Otherwise I would post examples and links.
ShaaraMuse3D ( ) posted Tue, 29 November 2011 at 10:36 AM
I tried the blender node, unfortunately it just gives me 50/50 of each image, rather than 100% background image, with the transparent image 100% strength on top of it. :(
Medzinatar ( ) posted Tue, 29 November 2011 at 10:47 AM
Try a "Color_math" node and multiply them
Anthanasius ( ) posted Tue, 29 November 2011 at 10:48 AM
screenshoot please ( or french :D )
Génération mobiles Le Forum / Le Site
vilters ( ) posted Tue, 29 November 2011 at 11:32 AM · edited Tue, 29 November 2011 at 11:33 AM
I worked witk a mask in this setup Full post here [ http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2832094&page=1](http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2832094&page=1)
Create a mask to control the blender
I give multiple solutions in the post.
ShaaraMuse3D ( ) posted Tue, 29 November 2011 at 12:51 PM
I looked through the thread that you posted vilters, and I got it. :) The trick to using the blender node seems to not just split and use the two images, but also use the blending connection and value to max, to filter with the transparancy.
Thanks for the help!
