Thu, Dec 12, 9:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Parenting a prop, and it moves
3doutlaw ( ) posted Sat, 31 December 2011 at 9:14 PM · edited Fri, 29 November 2024 at 4:18 PM
I seem to have all sorts of trouble with Parenting in Poser (and in real life, but thats another story ;-) ), for some reason.
In this case I load a prop, move it to the spot (lets say posed on a hand) that I need, and then I parent the prop to the hand.  The moment I do that, the prop moves?  Most of the time its a little twist or something, that I assume is relative to the hand, but I just wanted it parented as is...
Any setting maybe I am missing.  I learned in DS, and parenting in that wa just like attaching, nothing moved.  This is new to me that it is moving.  I don't get why it does it, or how/if I can stop it?
hborre ( ) posted Sat, 31 December 2011 at 9:40 PM
You could parent the prop using the hierarchy window.  Select the prop in the hierarchy and move it to the hand of your choice.  IIRC, doing it with this method will not cause the prop to move.  But I won't swear on that.
markschum ( ) posted Sat, 31 December 2011 at 11:45 PM
There is an option to inherit bends of parent. That may be messing you up.
rokket ( ) posted Sun, 01 January 2012 at 12:26 AM
Uncheck 'bends' on the properties menu also.
3doutlaw ( ) posted Sun, 01 January 2012 at 11:12 AM
OK, thanks I will try that.  Maybe that has been my problem all along.  Thanks!
3doutlaw ( ) posted Sun, 01 January 2012 at 6:53 PM
Parenting issues continued....ugh!!!!!
OK, so I load Hair prop (Mitsu Hair in this case), move to correct fit location, parent to head, bend head....and I get some deformed mess of stretching pixels and stuff?  What am i missing?
I have learned everything in Poser9 well enough, but Parent-ing, which I assume is a basic "stick to" just gives me fits!!!  (sorry, very aggravated right now...)
vilters ( ) posted Sun, 01 January 2012 at 7:27 PM
is that a hair with 2 objects?
The upper hair being parented to the lower hair?
And the parenting of the upper hair breacks when you parent the lower hair to the head with inherit bends checked ON?
3doutlaw ( ) posted Sun, 01 January 2012 at 7:45 PM
Nope, there is just one object/prop entry there.
This is fully repeatable.  I've tried now 3 prop hairs.
  1. Load Alyson2
  2. Load Prop Hair
  3. Object-> Change Parent to Head
4)Select Head
  1. Bend
  2. only the vertices that are in the head region are moving.
3doutlaw ( ) posted Sun, 01 January 2012 at 11:37 PM
OK, so this is due to "Inherit bends of parent" being checked, when parenting the prop.  Ends up that Shaderworks Adv Figure Mgr is set to do this by default.   ...and it stays this way, until a restart.
ugh...case solved, Basil notified.
3doutlaw ( ) posted Wed, 11 July 2012 at 4:39 PM
OK, I just ran into this again, and I stopped using Advanced Figure Manager, cause it was giving me other issues.
I think its a P9 bug?
If I parent a prop (using Object Change Parent) and select to Inherit Bends....it deform the object.
Then I undo that.
Then I parent that prop again (using Object Change Parent) and select to NOT inherit Bends...it still Inherit's Bends...  If I then choose to inherit Bends, it "double's up" on the inherit.
I am going to retry this on a basic scene...  argh!
3doutlaw ( ) posted Wed, 11 July 2012 at 4:45 PM
Yup...start with Andy
Bend, twist, side-side and grasp his hand.
Load Cane Primitive
Object -> Change Parent (NOT Inherit Bends) to hand
Cane is fine, parented to hand!
Edit Undo
Object -> Change Parent (Inherit Bends) to hand
Cane is whacked!
Edit Undo
Cane is Whacked!
...bad, bad Poser 9!  :(
Where do I report a bug?
3doutlaw ( ) posted Wed, 11 July 2012 at 5:00 PM
Posted at RDNA Poser 9/2012 Tech support forum, moderated by SM folks...
