Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Houlong Read your other post. Here is a shoot in the dark to try. Go to the "Window" menu up top on the interface. Then all the way at the bottom press "Document Window Size". At the popup make the window size smaller. Also make sure the "Lock Window" is unchecked. See if you cant move it now. Hope this helps. Ron
![file_167720.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_167720.jpg)
Opened up Poser and found my display window stuck in the upper right corner. I won't come out. I can change size and shape, but the upper right corner is stuck up under the file menu.Gordon
