Sat, Feb 1, 7:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
Subject: Possible Bug?
DreamlandModels ( ) posted Thu, 16 February 2012 at 11:48 PM · edited Sat, 01 February 2025 at 5:05 AM
Sometimes when I click on the cancel button for a render, Poser 9 locks up and will not pull out of it with out the use of Task Manager.
Is this a known bug? If it is not where can I report it?
Tom
ashley9803 ( ) posted Fri, 17 February 2012 at 12:00 AM
Heavy scenes will take some time to pull out of rendering. Are you being patient enough?
DreamlandModels ( ) posted Fri, 17 February 2012 at 12:04 AM
When task manager shows zero change in the core load for more than a minute I assume it is locked up.
The amount of processor used in bits should be fluctuating as long as the scene is trying to deal with canceling.
Might just be a windows thing.
Tom
LaurieA ( ) posted Fri, 17 February 2012 at 12:06 AM · edited Fri, 17 February 2012 at 12:09 AM
Tom: Go into General Preferences and make sure Render to Separate Process is checked. That should clear it up.
DreamlandModels ( ) posted Fri, 17 February 2012 at 12:09 AM
I did that just now. Thanks. We shall see if the issue continues.
What is the purpose of that tick box?
Tom
Eric Walters ( ) posted Fri, 17 February 2012 at 12:41 AM
 It happens in MacOS as well.
LaurieA ( ) posted Fri, 17 February 2012 at 8:52 AM
It makes Firefly run as if it was a separate program. If Firefly crashes, Poser won't, or at least that's the idea..lol. I just know that when I got Poser 7 I couldn't even use it until I ticked that box. Then it was great ;)
DreamlandModels ( ) posted Fri, 17 February 2012 at 10:27 AM
Thank you Laurie for taking the time to explain it to me. :-)
That helps me a lot to know why it is, what it is...
Tom
imax24 ( ) posted Fri, 17 February 2012 at 12:17 PM
They should re-label that button: "Check Here If You Want Poser To Render Faster And Crash Less. Leave Unchecked If You Like Interminable Renders And Occasional Lockups."
LaurieA ( ) posted Fri, 17 February 2012 at 4:17 PM
Quote - Thank you Laurie for taking the time to explain it to me. :-)
Tom
Hopefully that will clear it up for ya.
