Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
When Poser exports out an OBJ file it will also create a MTL file to go with it. This will include some material and texture information. Note however that whilst the texture files are named, their paths are not which can result in some 3D applications not being able to find them. To help over come this, suggest placing a copy of the textures in the same folder as the OBJ and MTL file.
Here's a cheap trick: First export to collada. Then export to obj in the same folder. Your textures will be right there. I have never been able to get collada to work right, but the texture export is a neat feature.
Poser 11 Pro, Windows 10
or you could be wildly daring and use the collectsceneinventory script which does the same thing and allows you to save all the textures to a folder after which just export the objects
My Freebies
Buy stuff on RedBubble
I know how to export v4 as an obj but don't know how to include the textures with it
any small tutorial on it would be great so I can follow.
cheers Rowlando
Seek what you can never loose
