Sun, Feb 16, 2:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: hidden cloth room settings in 2010
dorkmcgork ( ) posted Sun, 22 July 2012 at 11:39 PM · edited Sun, 19 January 2025 at 5:33 AM
anyone have any experience with these?  i guess to mess with them i'll have to open the pz3 in my text editor and change the values there since there's no dials for these in the cloth room.  they sound promising:
            U_Bend_Resistance    1.000000
            V_Bend_Resistance    5.000000
            U_Stretch_Resistance    50.000000
            V_Stretch_Resistance    50.000000
            Shear_Resistance    50.000000
            U_Scale    1.000000
            V_Scale    1.000000
            Density    0.005000
            Thickness    0.000000
            Spring_Resistance    5000.000000
            Air_Damping    0.020000
            Dynamic_Friction    0.100000
            Static_Friction    0.500000
            Friction_Velocity_Cutoff    30.000000
            Cloth_Cloth_Force    10.000000
            U_Bend_Rate   0.000000
            V_Bend_Rate   0.000000
            Cloth_Cloth_Friction   0.000000
            Damping_Stretch   0.010000
            get_friction_from_solid   0
            Use_Edge_Springs   0
            anisotropic   0
2 bend resistances 2 stretch resistances, u and v scale, edge springs, bend rate, friction velocity cutoff, cloth force...
anyway if anyone knows of any info on these i would appreciate hearing about it.
 maybe the doc has worked on em?
danke!
go that way really fast.
if something gets in your way
turn
LaurieA ( ) posted Sun, 22 July 2012 at 11:53 PM
Thickness???!!!
dorkmcgork ( ) posted Mon, 23 July 2012 at 12:30 AM
ha i didn't notice that!  yeah that is cool
turn
PhilC ( ) posted Mon, 23 July 2012 at 4:56 AM
http://www.philc.net/freestuff_archive.php
(Row 8, Column 2)
Here is a set of pose/scripts that will enable you to set the cloth values within Poser.
Very easy to use as a template should you want to customize.
The split U,V and thickness parameters are included in the script.
aRtBee ( ) posted Mon, 23 July 2012 at 11:18 AM
you might recognize some of them from the user interface (dials and checkboxes). In the U/V cases, the U value is used. Some are not used in Poser at all (Cloth Room is a purchased module, engineered into Poser 5)
More details on these specific details can be found on my Missing Manuals website, Poser Dynamics, part V, last section (Going Poser Cloth Room, page 16 and on in the PDF). You might like the other parts (I, II and IV) as well.
The settings as presented by PhilC, and others (SvdL, poserfashion.net, ...) will be discussed in Poser Dynamics part III which will be published on my site before the end of this month. Heavy reading, you've been warned :)
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
