Mon, Jan 27, 8:48 PM CST
Vue F.A.Q (Last Updated: 2025 Jan 24 7:34 pm)
Subject: Scale SEA
Theiamania ( ) posted Fri, 02 November 2012 at 4:43 AM · edited Fri, 24 January 2025 at 9:01 PM
Hallo everybody,
I can't understand how scale a sea just created.
If for example have a terrain with two lakes displaced at tow different altitude levels, I should create 2 sea, scale it about right dimensions of two different lakes and than place they.
Attach a draw...
Many thanks
Theiamania ( ) posted Fri, 02 November 2012 at 4:44 AM
[URL=http://img209.imageshack.us/i/img0819ra.jpg/][IMG]http://img209.imageshack.us/img209/1574/img0819ra.th.jpg[/IMG][/URL]
bruno021 ( ) posted Fri, 02 November 2012 at 6:13 AM
A Sea object is an infinite object, so you can't really have more than one, they would intersect and look bad when rendered. You can't scale an infinite object, because, being infinite, it has no limits. I suggest you use 2 cubes for your lakes. You can then use a metawater materail for your cube, but controls for foam and waves will only be available in  the function editor, less convenient than with a Sea object.
Theiamania ( ) posted Fri, 02 November 2012 at 6:20 AM
Quote - A Sea object is an infinite object, so you can't really have more than one, they would intersect and look bad when rendered. You can't scale an infinite object, because, being infinite, it has no limits. I suggest you use 2 cubes for your lakes. You can then use a metawater materail for your cube, but controls for foam and waves will only be available in  the function editor, less convenient than with a Sea object.
Great Bruno, as always, I-m gonna try!
Many thanks!
