Sun, Feb 16, 9:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Just received the Stripes for my 2005 Mustang
DreamlandModels ( ) posted Fri, 16 November 2012 at 6:24 PM · edited Tue, 11 February 2025 at 1:23 PM
Hi Guys,
After waiting several thousand years with great patience and anticipation, Ted gave me the Stripe Shader for my Mustang!
Ted you are the man!
Here is a look at it in action.
Yes it is a procedural.
I am going out of town for the weekend but hope to have the Mustang in my store about mid week, next week.
Hope you like it.
Tom
P.S. There are a bunch of cars in the lot, waiting to go online. :-)
monkeycloud ( ) posted Fri, 16 November 2012 at 6:27 PM
Yum. That looks good enough to eat ;-)
Have a good weekend Tom. I'll look forward to that appearing next week... and the rest.
Ragtopjohnny ( ) posted Fri, 16 November 2012 at 6:31 PM
Tom, it's a beauty! Well done!!!!! (Wish I could do cars like that......)
Poser Pro 2012/3DS Max 2013/Adobe Photoshop Elements 10/Zbrush/
PC: HP Z820 Workstation, 3.30 ghz 8 core Intel Processor, 2gig nvidia Quadro, 16 gig of Ram and 2TB Hard Drive.
DreamlandModels ( ) posted Fri, 16 November 2012 at 8:06 PM
Glad you like it guys as it is a labor of love.
Love banging my head against the wall. :-)
Will have a few color presets but you can change the two colors with two color selections right up front in the shader, as always Ted put the controls you can fool with on the left side.
Also has controls for the width of the stripes. Not a simple thing, so I will  most likely do a small tutorial for the shader. Took Ted a while to explain it to me.
Not because he is dumb. :-)
Bunch of controls for this car as well. Even figured out how if once the car is turned you can drive it straight in that direction.
Scoop is morph-able as well as the spoiler.
Wipers work as well.
All options can be hidden as always. Hide Show poses for all of them.
Steer right or left  and the steering wheel turns as you would expect.
Lights on or off material presets.
Bunch of wheel options for the colors.
Dark or light windows.
12 neon colors
45 Car Color Presets made from Teds BB2 Shaders pack a merchant resource product coming soon. .mc6 files
Here is another look at the rear end of the car. The spoiler has two morphs. One for the height and one for the amount of down force on the back of the car, when the cops are chasing you. :-)
Tom
HeyDork ( ) posted Fri, 16 November 2012 at 9:49 PM
This looks good, what is the poly count of the Mustang?
DreamlandModels ( ) posted Fri, 16 November 2012 at 9:57 PM · edited Fri, 16 November 2012 at 9:58 PM
Thanks
36,597 polygons
I like to model with quads
ToxicWolf ( ) posted Fri, 16 November 2012 at 11:09 PM
Really beautiful work.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
LaurieA ( ) posted Sat, 17 November 2012 at 12:41 AM
Does it come with the engine sound? LOL
Good work ;)
bagginsbill ( ) posted Sat, 17 November 2012 at 9:08 AM
The stripes shader is procedural - three numbers and two colors make infinite options. Here is the test render I did for Tom.
monkeycloud ( ) posted Sat, 17 November 2012 at 9:32 AM
That is very cool 👍
Looks awesome on the Mustang.
Is the Mustang UV Mapped / Poser mat grouped in a special way for this to work?
bagginsbill ( ) posted Sat, 17 November 2012 at 10:22 AM
Not special - it's just a longitudinal mapping, planar projection, from above.
The stripe does simple arithmetic on the U coordinate. (0=left, 1=right)
x = Abs(2 * U - 1)
This creates an 'x' value that is 0 at the center of the car (midline) and 1 at the edges - it creates mirror symmetry on either side of the midline. Any function of x will be mirrored and look the same on both sides.
To create a transition for the edge of a stripe, I want a fast ramp from 0 to 1 at key places. A simple way to do that is:
Clamp(200 * (x - p))
where p is some arbitrary x value.
For example, if I want a rapid transition from 0 to 1 starting at .25, I use
Clamp(200 * (x - .25))
When x <= .25, this is 0.
When x >= .255, this is 1.
Between those two I get a smooth gradient. This will make the appearance of an anti-aliased edge.
To do the opposite transtion from 1 to 0, ending at some coordinate, q, I reverse the subtraction:
Clamp(200 * (q - x))
Now to make a stripe from p to q, I can just multiply these two.
Clamp(200 * (x - p)) * Clamp(200 * (q - x))
To make two stripes, one between p:q and the other between r:s I use
Clamp(200 * (x - p)) * Clamp(200 * (q - x)) + Clamp(200 * (x - r)) * Clamp(200 * (s - x))
and so on. I can make any number of stripes this way, but i decided to do three.
The above is a royal pain in the ass to do by hand assembly of nodes, but with matmatic I literally typed the above into the script and it made the correct nodes for me.
bagginsbill ( ) posted Sat, 17 November 2012 at 10:29 AM · edited Sat, 17 November 2012 at 10:30 AM
Instead of having to type two numbers for each stripe, I decided to use a single number, and take the part to the left of the decimal to be the stripe width, and the part after the decimal to be the gap width (distance to the next stripe, or midline). I divide the stripe width by 100, so you can think of these as a pair of percentages.
In this way, I can just type three numbers - inner, middle, and outer stripe.
Example: 2.26, 10.01, 20.01
Produces what you see in the attached image.
That says:
I want the inner stripe (the one closest to midline) with 2% width that is 26% away from the midline.
I want the next stripe to be 10% width, and spaced out 1% from the previous stripe.
Finally, the outer stripe is 20% width, also spaced out 1% from the previous stripe.
bagginsbill ( ) posted Sat, 17 November 2012 at 10:41 AM · edited Sat, 17 November 2012 at 10:42 AM
This one is 2.10, 20.02, 2.02
bagginsbill ( ) posted Sat, 17 November 2012 at 10:53 AM
I set it up so that if the inner stripe has no fraction, then the left and right copies will merge, creating a central stripe as shown here.
This is 18, 1.01, 1.01.
aeilkema ( ) posted Sat, 17 November 2012 at 4:01 PM
Love the Mustang, looks great, always has been one of my favourite cars.
I gather we are allowed to make commercial announcement again, since you guys create quite some threads that are purely commercial...... I thought that was against the rules, but it seems these rules have been lifted now.
Food for thought.....
bagginsbill ( ) posted Sat, 17 November 2012 at 5:18 PM · edited Sat, 17 November 2012 at 5:19 PM
It's not a commercial thread, although I notice you want to complain about anytime we talk and there happens to be something we're working on.
Tom was happy because I finally gave him the shader he asked for. I'm not selling this shader.
Then I gave the math formulas, making it a tutorial.
Course, you're free to teach us what YOU know if you like.
bagginsbill ( ) posted Sat, 17 November 2012 at 5:21 PM · edited Sat, 17 November 2012 at 5:22 PM
I'm thinking I'm kind of sick of Rendo forums and maybe I'll just go make my own somewhere.
I rarely read something worth reading anymore. Much of what I read makes me experience negative emotions toward the poster.
I try to post informative and interesting stuff, because there seems to be precious little of it.
But do go on and make me bitter. I will find more time to do paid work.
primorge ( ) posted Sat, 17 November 2012 at 6:01 PM
... Please don't abandon the forum outright, BB. Even when you seem to be irritated you still post invaluable tips and suggestions.
As an aside, I have noticed that your tone has changed from what it once was in various forums... I also read a comment from SnowSultan on her site that she no longer attends the renderosity forum because of the "New Crowd".
In any case, here's hoping that you just let the nonsense slide and continue to be the Material Master @ the Rendo Poser Forum.
DreamlandModels ( ) posted Sat, 17 November 2012 at 6:08 PM · edited Sat, 17 November 2012 at 6:20 PM
Don't think you complained when Blackhearted has threads about his products or several other threads here. Even one at the top that is sticky, about a tutorial, posted by a staff member.
Seems like you just plain do not like Ted.
Why don't you go somewhere else.
Ted is doing a ton of good for Poser world!
What are you doing?
Beside trying to stir things up.
Please be kind in your comments or don't comment at all.
As Ted said above, I am just happy to have the shader that he spent hours and hours createing.
Tom
P.S. Ted had an older version of the Mustang so if you see a strange mismatch in the mapping it has already been corrected. :-)
Khai-J-Bach ( ) posted Sat, 17 November 2012 at 6:17 PM
guys guys... calm
remember.. if aeilkema complains... it's actually good. tis how you know you've got it right ;)
DreamlandModels ( ) posted Sat, 17 November 2012 at 6:17 PM
LaurieA ( ) posted Sat, 17 November 2012 at 6:26 PM
Hehe...I don't mind the commercial threads anyway, even if this one isn't really ;). Oh, and btw, they DID lift that, so ner. LOL
DreamlandModels ( ) posted Sat, 17 November 2012 at 6:28 PM · edited Sat, 17 November 2012 at 6:30 PM
LaurieA,
Your tag line scares me.
I used to be married so you know,
I don't scare easily.
Also, your cat is cute. :-)
Tom
LaurieA ( ) posted Sat, 17 November 2012 at 6:41 PM · edited Sat, 17 November 2012 at 6:42 PM
LOL. Funny, hubby said the same thing ;)
Hahahaha.
BTW - yes, she is cute. Hehe.
DreamlandModels ( ) posted Sat, 17 November 2012 at 7:13 PM · edited Sat, 17 November 2012 at 7:14 PM
Looks like my sons cat. Franky is a mancoon and weighs about 14 lbs.
Big and dumb, but lovable!  :-)
Yes that is my nap chair and he fills it quite nicely.
aeilkema ( ) posted Sun, 18 November 2012 at 2:46 AM · edited Sun, 18 November 2012 at 2:50 AM
Quote - Hehe...I don't mind the commercial threads anyway, even if this one isn't really ;). Oh, and btw, they DID lift that, so ner. LOL
I don't mind either, just wondered that's why I asked, thanks for answering. Of course this is thread commercial at any forum a mod would edit and flag it as that. but I'm sorry for asking the question in this thread, no need to get all angry, it's just a question and it's answered now, so I'll be on my way again.
monkeycloud ( ) posted Sun, 18 November 2012 at 4:02 AM
That stripe technique is very cool 👍
The insight into how it works is very much appreciated BB...
Looking forward to getting that car too...
...and nice cat Tom... ;-)
