Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
If it is a morph you can set the dial to -1, spawn a new morph, then zero the original and use the new.
You can add another dial and link the two using ERC code with a negative add delta.
Or possibly more simply rename the dial to something like fold-unfold which will give the hint that the dial should/could be moved in either direction.
Thanks for the replies phil and mark.
Quote - You can add another dial and link the two using ERC code with a negative add delta.
I've just done some poking around and it seems that is how I did it previously. Sometimes I amaze myself.
I think that this time simply renaming the dial will do the trick. I might go one further and re-import the part in its other position (up instead of down - it's a simple hinged flap thing) so the dial makes more sense - turning it down makes the thing go down and vice versa.
I have a dial which has to be turned from 0 to -1 to fold a bodypart. Since that's a bit counter-intuitive, I want to reverse the dial so it goes from 0 to 1.
I know I've done it before but I can't remember how I did it (that happens a lot these days). I may have used Easypose Underground but it's not currently installed so I was wondering if there's a simple way to do it in PP2012?
