Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Visit the Carrara Gallery here.
This should work fine. Try to create an empty scene with this backdrop to see if it will work.
Follow me at euQfiz Digital
This may be a simple problem to solve but I'd appreciate some advice.
I have a Carrara scene where I want an animated backdrop, so I've set the backdrop shader to "Map" and loaded a JPEG sequence from 0001.JPG to 0240.JPG. The slider on the preview window shows that the images have sucessfully loaded and animate properly, but the exported animation shows the first frame only for its whole length.
Should I be adding keyframes to the backdrop, for example? Any hints welcome.
I'm in Carrara 7 Pro.
