Mon, Feb 17, 7:19 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
Subject: PP2012 Conforming Clothes Issue since SR 3.1
mackis3D ( ) posted Mon, 06 May 2013 at 3:04 AM · edited Mon, 17 February 2025 at 1:12 PM
Hi,
I have a problem with some conforming clothes since I've installed the SR 3.1 for Poser Pro 2012.
In this case it's the Tank Top for Apollo Maximus. It works as it should on the image that was done in Poser Pro 2010. It did work with Poser Pro 2012 before I've installed the SR 3.1. I missed the SR before that so I cannot say whether the problem was established prior to SR 3.1.
Does anyone of you have a similar problem?
So far I still use PP2010 to pose the figure with clothes, save it as a *.pz3 scene file and open it again in PP2012 - where it keeps the proper conforming look from PP2010 as long as I don't move the Apollo character.
raven ( ) posted Mon, 06 May 2013 at 3:20 AM
I just loaded AM and then the tank top and conformed it, and got the result you posted.
However, I then went into the properties panel of the tank top, checked the box for 'Match end points when conforming' and the tank top then fitted correctly.
mackis3D ( ) posted Mon, 06 May 2013 at 4:52 AM
Oh... that really works. Thank you!
EnglishBob ( ) posted Mon, 06 May 2013 at 11:03 AM
I had a similar problem while testing a Miki 4 outfit on Poser 9, also at SR3.1. I raised it as a problem with the vendor. I assumed the outfit had incorrect end points, but I compared them with Miki 4's and they were identical.
Is there an issue here? I've since had other conforming problems apparently associated with Poser 9, and not all were fix-able with this workaround. However I am still a blundering newbie with P9 so I may have missed something.
Magic_Man ( ) posted Mon, 06 May 2013 at 5:11 PM
What is the guidance as to when to use the four "...when conforming" checkboxes?
ashley9803 ( ) posted Tue, 07 May 2013 at 1:45 AM
Quote - What is the guidance as to when to use the four "...when conforming" checkboxes?
Pages 191 & 192 in the PP2012 manual.
Magic_Man ( ) posted Tue, 07 May 2013 at 12:59 PM · edited Tue, 07 May 2013 at 1:08 PM
Thanks... ;)
Have these been in previous versions or just on by default?
in terms of drag/drop from the library and auto conforming, are these options implied on or off?
wimvdb ( ) posted Tue, 07 May 2013 at 1:57 PM
Quote - Thanks... ;)
In one of the P9 SRs the scaling (animated joints) problem was tackled. When the did that they discovered some incompatibilities with some figures because the CR2s were not correct. SM added those option boxes to fix those figures.
Default those options are off when conforming
Magic_Man ( ) posted Wed, 08 May 2013 at 3:26 AM
Thanks
