Fri, Nov 22, 1:02 PM CST
Subject: PP2014 Preview Settings Problem...
onimusha ( ) posted Sun, 09 June 2013 at 7:16 AM · edited Mon, 18 November 2024 at 3:05 AM
So I want my preview settings to have "Enable Hardware Shading" unchecked.  Most of the time it loads up like this.  Once in a while it will start loading it with it checked.  Any way to keep this from happening?
R_Hatch ( ) posted Sun, 09 June 2013 at 10:43 PM
Your image isn't showing up. However:
  • Is your GPU capable of supporting hardware shading?
  • Are your GPU drivers up to date?
JoePublic ( ) posted Mon, 10 June 2013 at 1:32 AM
Does it switch settings when you load a pz3/pzz ?
The preview settings usually will obey the scene that is loaded.
If your "preferred scene", the one you start with, is set to no hardware shading, then Poser should start with no hardware shading.
But if you open a scene that uses hardware shading, Poser will use hardware shading as long as the scene is open.
Unless you switch it off manually.
If Poser switches arbitrarily, then there must be a bug somewhere.
