Sun, Feb 16, 2:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Lights effect... how do this ?
xpdev ( ) posted Tue, 23 July 2013 at 2:41 AM · edited Tue, 23 July 2024 at 12:26 PM
how can i can play in poser pro 2014 to do this kind of light effect ?
thanks
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
TrekkieGrrrl ( ) posted Tue, 23 July 2013 at 5:12 AM · edited Tue, 23 July 2013 at 5:15 AM
You could make an atmospheric fog. But it's a bit (hah! a lot) tricky to control. I think I'd use the depth cue thing and blend two renders in Photoshop (or similar program)
Haze like this is one of the things I'd wish were easier to do in Poser. It looks so pretty.
Come to think of it, the Terra Dome has some atmospheres... I have used them, but it's ages ago so I can't remember if they worked for this.
Hmm
ETA
I can see I did use postwork the last time I tried something like this. Unfortunately I didn't note anything else about it, other than I'd used postwork because Poser's fog was too unreliable. Dang.
Example:
http://www.renderosity.com/mod/gallery/index.php?image_id=2153864&user_id=83499&page=2&member&np
xpdev ( ) posted Tue, 23 July 2013 at 5:42 AM
yes, i have made some tests with atmospheric fog, but i was not lucky, very hard to control e not good results...
Can I ask you a question?
right now I have problems to light in the correct way the scenes that you see ....
you have any suggestions ?
Ps don't care about quality.... only lights...
LaurieA ( ) posted Tue, 23 July 2013 at 7:08 AM
Poser doesn't really do bloom. Ya might try Luxrender, which does.
bagginsbill ( ) posted Tue, 23 July 2013 at 7:50 AM · edited Tue, 23 July 2013 at 7:53 AM
Quote - You could make an atmospheric fog.
This effect is not fog - it's bloom as Laurie said. Look at the top of the left-hand column - observe how the back side which is in shadow is filled with light. Fog would not do that.
http://en.wikipedia.org/wiki/Bloom_(shader_effect)
It is best applied as a post-work 2D effect, and will be most effective if you save your image in HDR format.
Quote - Current generation gaming systems are able to render 3D graphics using floating point frame buffers, in order to produce HDR images. To produce the bloom effect, the HDR images in the frame buffer are convolved with a convolution kernel in a post-processing step, ...
bagginsbill ( ) posted Tue, 23 July 2013 at 7:55 AM
Here is bloom (and some lens flare) in a photo I took on a totally clear-air sunny day. It is purely a camera artifact, not something in the actual world.
xpdev ( ) posted Tue, 23 July 2013 at 8:05 AM
Ok, thanks to everybody, i understand.
