Sun, Feb 16, 5:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Poser Pro 2010 stopped responding whilst rendering
art4me ( ) posted Mon, 11 November 2013 at 7:57 AM · edited Tue, 07 January 2025 at 2:04 AM
hello
Could you help please.
I am running Poser Pro 2010 on Windows 7, I am a amateur user.
After running Poser Pro 2010 for a year or so it has just started hanging up whilst rendering.
Example
I start the program and without loading any scene or figure render.
It seems to start to rendering and then stopped responding,
Computer says Poser Pro stopped responding.
I have set my render settings back to default and render dimensions to fit screen.
Same, problem
Any help with this appreciated.
Thanks
DarwinsMishap ( ) posted Mon, 11 November 2013 at 11:29 AM
How big is the scene you're rendering?  What props are you using?  Any complex shaders?  Do you have anit-malware running?
There are lots of reasons why your system may be getting hung up- and, sometimes, it can be a lack of patience on the user's end.  Don't click in the screen while it's running, you can actually lock it up yourself by "checking" it constantly.
Try not to run processor intensive programs while you render- the CPU may try to split the power between the programs and Poser may end up losing that battle.
try rendering just Andy in the scene, with the standard lights already in the scene when  you open PP2010. Does it render without problems?  Ok- if so, try going larger in the render size/resloution- like A4.  (2480x3508 pixels, 300 dpi)  If no issues, fine.  Try putting props in like M4, a room, car, clothes, etc.
Trial and error- and check your log in the Help tab, you may get a hint at what's going on in there.
TrekkieGrrrl ( ) posted Mon, 11 November 2013 at 12:35 PM
Do you render in separate process? It can help.
If so, check the task manager and look for Firefly.exe. If it keeps using more and more memory, it's still doing something even if Poser may report "not responding".
And as DarwinsMishap said, you can actually trigger it yourself by clicking the Poser screen :) Try starting the render and then go to bed/work and take a look some hours later :)
iborg64 ( ) posted Mon, 11 November 2013 at 3:30 PM
after i went on to windows 7 I found this happening a lot in poser 2012 then poser 2014 and vue 10 . Lots of looking around on the internet seemed to point the finger at windows 7 being a bit too keen to say a program was not responding when it was just a bit busy.None of the so called fixes did anything and the best answer I found was as others have said leav it alone when it says not responding and eventually it will start to respond again
randym77 ( ) posted Tue, 12 November 2013 at 7:39 AM
Seems kind of odd that he's been running Poser fine for a year, and only now is having a problem.  And it's hanging even if he tries to render without loading any scene or figure.
It sounds like it's not the usual memory or Windows issues.  Something else is going on.
paganeagle2001 ( ) posted Tue, 12 November 2013 at 7:50 AM
The first thing I would do is go and delete out what is in your Poser temp folder.
You can check where this is on the EditGeneral Preferences  option and then the Misc Tab.
Go into that folder and then delete everything. If you have never done this befiore you will find you may have gigs of temp files in there.
What may have happened is that one of the files you are using has set a temp file that has become corrupted and so it hangs.
You cannot do any damage to your system by deleting the files in that folder.
All the best.
Great Uncle LROG
Who honors those we love for the very life we live?, Who sends monsters to kill us?, and at the same time sings that we will never die., Who teaches us whats real?, and how to laugh at lies?, Who decides why we live and what we'll die to defend?, Who chains us?, and Who holds the key that can set us free... It's You!, You have all the weapons you need., Now Fight!
