Sun, Feb 16, 2:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: LuxRender, Reality Plugin & Poser Q?
mouser ( ) posted Wed, 27 November 2013 at 5:37 AM · edited Sun, 02 February 2025 at 11:04 AM
Just installed LuxRender as a replacment for Firefly, it accesses Poser via the Reality 3 plugin.
Impressivly faster rendering images but I've run into a snag.
The Library window in Poser is now Blank, everything else works fine though.
Has anyone else hit this issue and resolved it?
Sytem info
Win7 64bit
i7 cpu
8gig ram
hborre ( ) posted Wed, 27 November 2013 at 8:15 AM
It might be something totally unrelated to LuxRender.  Have you recently run a Windows update?  Other related threads cite problems with the installation of IE11.  If that is the case, you will need to rollback to latest backup and prevent IE11 from automatically installing.
Pret-a-3D ( ) posted Wed, 27 November 2013 at 9:21 AM
Hi. That is generally an issue with IE and Poser. what version of Poser are you running? What version of windows?
Cheers
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
hornet3d ( ) posted Wed, 27 November 2013 at 11:53 AM
I have Reality 3 with Poser 2014 running on Windows 7 64bit also on an i7 system and I have never seen the problem you have described.  Like the others I suspect there is another reason for the blank window.
mouser ( ) posted Thu, 28 November 2013 at 2:47 AM
Library window went blank after I installed Luxrender & Reality 3 but before I installed Python.
Not sure what the cause is, no error messages just a blank window.
mouser ( ) posted Thu, 28 November 2013 at 7:02 AM
Updated both Adobe Flash & air but no luck.
Pret-a-3D ( ) posted Thu, 28 November 2013 at 10:06 AM
It's the latest update to IE that usually need to be installed. The Library uses IE components.
Cheers.
Paolo
Tw: @preta3d
mouser ( ) posted Fri, 29 November 2013 at 2:31 AM
All window updates added, no change.
Still investigating.
mouser ( ) posted Fri, 29 November 2013 at 6:50 AM
Found the little $h1t, Preferences->Library->external.
mouser ( ) posted Fri, 29 November 2013 at 7:27 AM
Phew now its all finally working, time to test Luxrender & Reality3.
Setup a larger render scene this time (1920x180)
Luxrender is definetly slower but the render is better quality, eventualy.
Strange how it just keeps going until you decide to stop it but hey it works.
Much experimenting to do ahead.
IGOR the storm is at its height quick throw the switch,
         ITS ALIVE! ITS ALIVE!
Pret-a-3D ( ) posted Fri, 29 November 2013 at 8:52 AM
Hi Mouser.
Glad that you found and solved the issue.
Cheers.
Paolo
Tw: @preta3d
mouser ( ) posted Fri, 29 November 2013 at 4:33 PM
Thanks everyone for the advise;)
