Sat, Jan 11, 8:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
Subject: Loading 2 of the same hair prop on one figure
MoxieGraphix ( ) posted Mon, 06 January 2014 at 2:22 AM ยท edited Sat, 11 January 2025 at 8:26 AM
Sometimes when working with hair I like to use two of the same hair, adjust the size a bit of one of the hairs, and use complimentary textures. It adds depth to an image. This works well with hair that is a figure or one that has both a cr2 and an hr2 version. But if there is only an hr2, I can not load two of the same hair prop onto one figure. Is there a workaround for this? Am I complete idiot and it's pretty simple? Is it not possible at all?
PhilC ( ) posted Mon, 06 January 2014 at 2:31 AM
Hair props are preset by Poser to replace any existing hair, it is hard coded into the program. Copy the HR2 file into the a props folder and rename the extension to PP2.
MoxieGraphix ( ) posted Mon, 06 January 2014 at 5:10 AM
Thanks! I'll try that. I KIND OF thought that might be the case, but I had to ask.
lkendall ( ) posted Tue, 07 January 2014 at 10:55 AM
You can also preprepare your hair, export it as an object, re-import it, size it, and position it. Then parent it to the head.
